11-04-2009, 09:38 PM | #1 |
bolt hole problem
Can the head on a 350 be welded on?Somebody mess up the bottom bolt for the altanator.They tried to get it out and made it worse.
77 swb starting all over again. |
11-04-2009, 10:19 PM | #2 |
Re: bolt hole problem
Yes you can. Clean the broken bolt in the head than hold a nut next to the cylinder head with a pliers and weld the nut to the broken bolt. Than take a wrench to the welded nut and remove your broken bolt. You must get good penetration and fill the whole nut to make sure the nut does not break off.
11-05-2009, 01:01 AM | #3 |
its all about the +6 inches
Or you can get the correct parts and install the alt on the drivers side.
11-05-2009, 01:42 AM | #4 |
I thought about that its going on a 76 chevy.I may have to do that.
11-05-2009, 07:18 AM | #5 |
wel a 76 is supposed to be on the passenger side. I guess since this is on the 67 - 72 forrum, I assumed it was for a 67 - 72 truck.
11-05-2009, 07:50 AM | #6 |
if the bolt holes on the rear of the heads are ok you can switch the heads side for side and you'll have good holes in the front
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 11-05-2009 at 09:49 AM. |
11-05-2009, 08:20 AM | #7 |
"THE GREEN GOBLIN"
WOW good to know I didn't even know that was possible.....
Petey-pablo
"THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi Sold Drive it like you stole it! Petey-pablo@sbcglobal.net |
11-05-2009, 12:53 PM | #8 |
Hey Barney, where did you pick up the '69? Do you have some more pics of it? How did it go at CAT?
Nick "Everyone has a plan, 'till they get punched in the mouth".........Mike Tyson 1968, GMC, SWB, Project 1972, GMC, LWB, Daily Driver, 383, headers, 2.5"/3" exhaust, 200r4, 3.5/5 ECE components. 1972, C/10, LWB, 350 vortec, th350 |
