Old 11-04-2009, 11:58 PM   #1
sure_green
Using OEM AC Brackets with headers?
Can someone give me some guidance on mounting and OEM compressor with headers?
sure_green is offline   Reply With Quote
Old 11-05-2009, 12:23 AM   #2
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Re: Using OEM AC Brackets with headers?
I am guessing you are talking about small block brackets. In this case, there are custom brackets out there, or you will have to cut the bracket that bolts around the factory manifold. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 11-05-2009, 12:26 AM   #3
americanmusc1e
americanmusc1e's Avatar
use a notched bracket
and longer header studs and spacers
-- Josh
Instagram: @americanmusc1e
OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread
FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread
1999 4wd OBS Tahoe - daily.
DM me if you can't see photos i posted
americanmusc1e is offline   Reply With Quote
Old 11-05-2009, 02:48 AM   #4
cparman
sharp as a marble
i am guessing that you are talking about the bracket that mounts to the rear of the A/C compressor. If you look in a jegs catalog, they will chow a bracket, that mounts to the header flange and give you a hole to hold the lower rear compressor mount. In process with a 70 Camaro, and needed the same thing.
cparman is offline   Reply With Quote
Old 06-01-2011, 04:12 PM   #5
caboutin
caboutin's Avatar
Can we get some photos of all this please!!! I can't figure out where to attach the rear a/c bracket. Does it go to the manifold or what???
caboutin is offline   Reply With Quote
Old 06-01-2011, 06:30 PM   #6
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
If I understand your last question, my 350 had a stud on the right side, at the front of the intake, which served to locate the rear of the original ac compressor. Here's a pic of the front of my engine before I pulled it from the chassis. I hope it will help.
Member Nr. 2770
