11-05-2009, 12:41 PM | #1 |
buffing old paint
Any body have any luck buffing old paint?I've hand polished(buffing comp)but it still needs more or should I say it needs to be done correct.Any help would be great!Clark.
11-05-2009, 12:59 PM | #2 |
Between Trucks...
Re: buffing old paint
Sorry, no help on the paint, but that's a sweet truck.
Beat it to fit, Paint it to match... |
11-05-2009, 01:08 PM | #3 |
Depends on what kind of paint it is I imagine, if its original and just faded I would try a buffing wheel with some fine cut compound like Megiures to try to bring it back, then wax the crap out of it. the main thing with a buffing wheel (wool pad) is keep it moving, not letting the heat build up, especically on a corner, or you'll burn through. Also use one with a speed control on it, start out slow then slowly speed things up when you are comfortable. Hope this helps...
"You can put lipstick on a pig, sure it's pretty pig, but it's still just a PIG... 71 LWB Last edited by UltraBlue71; 11-05-2009 at 01:10 PM. |
11-05-2009, 01:26 PM | #4 |
looks pretty good to me// using a buffer on old stuff is real chancy in a matter of seconds you can burn thru that old finish . i've seen it done countless times BEWARE
11-05-2009, 03:39 PM | #5 |
Most of the colors on these trucks will buff out nice. But a few of the colors with metalic like the bronze or your color green, If they get too faded no amount of buffing will bring back the shine. Yours looks pretty good though.
72 Cheyenne Super 80 Silverado Blazer 2wd |
11-05-2009, 05:33 PM | #6 |
Parts and more parts
The truck that is pictured has the green paint, that once it starts to age it will slowly turn black as the base coat shines throught. My 72 had that color and I finally just repainted the truck to end it's pain. It would be nice, if the older paint jobs were the base coat/clear coat paints of today. but they weren't--so they ploishing of that paint is hard to do without going too far. Topolish paint a mild rubbing compound and a large wheeled, slow speed buffer works best. Once polished, then reseal the paint with a good polish or sealant.
Frank |
11-05-2009, 06:19 PM | #7 |
i'd suggest the 3m finesse-it 3 system with a foam pad. the foam pad is a lot more forgiving to burn thru and is a lot easier on the crowns and edges. if you are not familiar with machine buffing techniques. do a search for videos on how-tos
-02 avalanche (daily driver) -66 gto ragtop 389/400 (garage queen, hand-me-down from dad) -72 Tribute Trans Am (6.0LS/T56 6-speed) in progress -2003 YUKON (Wife's) -71 gmc swb fleet (current project, gonna shave everything, bags, stuff w/ 20's, gen III powertrain) -48 3100 SWB - 12/31/23 LONG TERM Project |
11-05-2009, 06:54 PM | #8 |
Not worried about going through the paint there are dents and scratches all over,this was a farm truck...I just want it to shine!Funny thing is that the box,hood and fenders are painted over black and the cab and doors are painted over red primer???Any reason for this?And it is the original paint.
11-05-2009, 08:09 PM | #9 |
mini truck racer
I have a porter cable double action polisher that takes foam pads of different aggresiveness . I would start with a white lake county pad and a #6 cleaner/wax . Easing up in aggression only if needed . Orbitals are alot more forgiving and work good if a soft cut is needed .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
11-06-2009, 11:06 PM | #10 |
Yes, that is the way it was done at the factory, but don't know the reason why.Your factory paint looks very presentable the way it is, how many base coat clear coat jobs will last 40 years?
11-07-2009, 05:23 PM | #11 |
If it is done right, the paint will last a long time, no matter what the type.
Frank |
11-05-2009, 08:21 PM | #12 |
Moderator
Use a clay bar. They work fantastic.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
11-05-2009, 10:01 PM | #13 |
"It`ll buff out."...No i really mean it!
The paint on these trucks was awesome.It`s unbelievable how well it can be revived.But,do be gentle.There`s been some great advise offered already.
11-05-2009, 10:27 PM | #14 |
70 Chevrolet=Obsession
All of the above advice is excellent but I might add it depends on how deep the dead (oxidized) paint extends into the thickness of the paint. If the paint is really dead, you'll break through to the primer before you reach any shine. If this is the case only repainting your truck will solve it. As to the doors and cab having different color primer, it sounds like maybe they had some body work done on them at some time.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke! IT'S NOT EASY BEING GREEN! -Kermit the frog 1970 Chevrolet C-10 Longbed Stepside : 350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes) 1996 Toyota Corolla (Parts runner) |
11-05-2009, 10:42 PM | #15 |
motor exploder
Meguiar's 'Swirl mark remover 2.0', Mother's cleaner/wax, then Mother's carnuba wax - I applied the Meguiar's 2.0 with a craftsman buffer (not orbital/DA sander) then the cleaner/wax with the buffer and hand applied the polish/final wax. Worked great on the single stage paint on my '69. I should've taken a pic of the whole truck before I started, but I took one of the inside of the bed, inside the yellow circle is what the whole truck looked like. the second pic is right after I backed it out of the garage after buffing/waxing.
Before this, the truck had sat outside for about 10years uncovered...
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! Last edited by BossHogg69; 11-05-2009 at 10:43 PM. |
11-05-2009, 11:38 PM | #16 |
As mentioned before, my 72 suburban had dull paint like the blue one pictured above. Used Meguiars swirl and scratch remover and buffed it by hand, it ended up looking like a new paint job again.
I don't always drive trucks; but when I do I prefer Chevy's. Stay driving my friends. '72 blazer 2wd build 67-72 Factory Big Block Registry |
11-06-2009, 12:07 AM | #17 |
+1 on the meguiars products...
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
