11-06-2009, 01:14 PM | #1 |
what a day check it out Please
Ok got up thismorning started up my truck and it made one hell of a grind/squeel sound then it stop let it warm up for a while no squeel or grinding sounds as it idles I get into the truck take off down the road and it did that squeeling sound/grinding sound again i stop the truck and got out popped the hood went to turn the truck off and the darn thing wouldnt shut off so i went out anyway to check under the hood and there was alittle steam coming from one of the valve covers so i got back in the truck and came back home and itmade that grinding sound all the way home about 4 blocks so i went to get some tools to unplug the battery when i came back the truck was already shut off!! Can annyone give me any ideas on what happen or what i should start replacing and ect thanks aot for everything
11-06-2009, 01:41 PM | #2 | |
Re: what a day check it out Please
Does this truck have Air Conditioning?
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
11-06-2009, 02:36 PM | #3 |
11-06-2009, 04:36 PM | #4 |
How about engine/trans info. Is it equipped with an air pump?
11-06-2009, 04:47 PM | #5 |
11-06-2009, 05:09 PM | #6 |
i would look at the wires on the starter, and see if they are almost touching or are melted. then I would get the starter checked. I had a 79 suburban that the starter stayed engaged and it had burned up the battery and was makeing the same noises that your describing.
which valve cover is the steam coming from?
2017 Tahoe Premier - Daily '99 Silverado 2500 Wife's whip- 2020 Equinox Premier |
11-06-2009, 07:20 PM | #7 | |
11-06-2009, 07:23 PM | #8 | |
Still plays with trucks
11-06-2009, 07:43 PM | #9 |
11-07-2009, 02:36 PM | #10 |
thansk for everyones help problem is solved it was the starter and the wires were alittle fried and melted but its all fixed now thanks again
11-06-2009, 07:21 PM | #11 |
The starter wiring sounds like a good place to start. It may have gotten melted and is keeping the solenoid engaged longer than it should.
It may be melted plastic smoke you are seeing and not steam. |
11-06-2009, 07:11 PM | #12 |
Great answer. Prolly shorted wires to starter OR stuck solenoid.
