11-07-2009, 06:15 PM | #1 |
Will a ps box from an 83 bolt in a 68?
I have a 68 with stock power steering however the box is leaking pretty bad.
I can get another box from a 83 but need to know if it will bolt in and use the same hoses that I have on now. If anyone could shed some light on this change I would really appreciate any insight. Thanks Scott
1963 C10 swb fleetside 1966 GMC G1000 Handi-bus (future project) 1955 Chevy 2 dr. wagon |
11-07-2009, 07:26 PM | #2 |
Re: Will a ps box from an 83 bolt in a 68?
It will bolt in but you have to change your hoses or use the pump off the 83.I did it on my 67.
77 swb starting all over again. |
11-08-2009, 10:08 AM | #3 |
What all years will bolt in place?
85' CUCV M1009!!! The newest addition! 6.2diesel, Th400, NP208, & only 36k miles! 70' C-10 LWB Fleetside - Looking good these days! 05' Dodge Neon 88' Winner Escape Sport 1750 - 4.3v6 94' Seadoo SP 84' Honda TRX200, bare nekkid. Just a frame & tires. Always looking for another project or any good deal! |
11-08-2009, 12:36 PM | #4 |
Watch out for your cornhole !
You don't have to change to the later model pump just because the hose ends are different. You just unscrew the 1 inch hex fitting out of a late model pump and screw it into your old pump. They interchange and this gives you the proper fitting you need for the late model hose.
11-09-2009, 11:43 PM | #5 |
Hellasick
the big problem I had with using an '85 ps box on mine was not finding any metric-o-ring lines that would fit the truck. Just convert the '83 to a flair line box.
http://67-72chevytrucks.com/vboard/s...d.php?t=242458
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes) This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do. RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!! BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys |
11-10-2009, 04:40 PM | #6 |
Great info guys, thanks!
