left rear lower than right rear... 2 inches
i noticed this problem and it seems to be getting worse. i have lowering springs. 5 inch ones from classic industries i think. the driver side tucks the tire a bit and the right rear has wheel gap. the bed is bolted on all the way and i have the rear centered with an adjustable track arm.
simply put you think it's in the coil spring quality? |
Re: left rear lower than right rear... 2 inches
is the front the same on bolth sides?? check your control arms, make sher there not bent.
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308 2014 Chevy 2500hd duramax CCLB |
I had the same problem and found out that the frame had a slight bend right by the coil spring pad. Get under the truck and measure the spring with the weight on it, trailing arm to frame and you might find the problem. I tried another set of coils [ Moog springs] and had the same problem right to the same inch. At first i thought it was the trailing arms but the new set had the same problem. I hope this helps because it took me hours on the alignment rack measuring suspension heights to figure this out.
Redefining LowBudget
also make sure your front springs are even also...if I have a little more air if one front bag is make the truck look like yours
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
i cut my front coils a whole coil for 2 inches. they appear equal.
i just did my c-notch and had this unlevelness problem before and after the job. i didn't notice anything out of square while doing the labor on the frame. here's some ground to fender centerline measurments. Front ---- L 28" ----- R 28" Rear ---- L 27" ----- R 29" |
#6 | |
![]() Join Date: Apr 2005
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 11-09-2009 at 12:08 AM. |
strongly agree with hartrod....wont cost you any money...if you swap the springs from one side to the other and the problem went to the other side...then trash the springs because thats obviously the problem...just some labor but hey atleast you wont have to buy a new set of springs just to check for the problem, if you have to buy new set you will already know they are going on the truck...
that's a great idea guys. i'll have to try that. sometimes i over-think and need to hear others mention the obvious.
it's a common issdue chevy frames that see lots of heavy use get tweeked
hmmm how did you cut the fron springs whiz wheel in water or a trouch.......you know where I'm going with this don't you???
#11 | |
another note, i'm using a blazer tank in the center of the frame. |
it's just something to look out for..we scale the race car and which ever wheel needed it we would add wedge or take it out..basicly the weight one wheel carries will affect the how the car handles
Tot Roddin'
A simple question, but I have to ask....
Were the rear springs the same height before installing? Sometimes when you order a 5" spring there's an opportunity for them to send you different spring heights. Swap the springs from side to side and if the height difference changes sides... I'd call CPP. If it stays on the same side, measure the frame.
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
rear springs appeared equal and it slowly got worse. a year ago the truck was level, then i noticed lately when coating my tires i couldn't get to the driver side as easy as the passenger side.
