11-10-2009, 02:25 AM | #1 |
What is Recomended for cleaning out Engine?
i got my engine finally put back together, and when i went to start it up, it fired right up
buuuuut.....i made a custom set of valve covers for easier valve adjusting, and within a few seconds of the engine running, i spotted some milky residue coming up on the rocker arms.... i got a few opinions and everyone said that it is just the oil pump picking up the milky residue at the bottom of the pan. that would make sense.... I NEED to know if there is any way of clearing all that crap out? like an additive or something? thanks
Greg 1974 GMC 1/2 Ton SWB Fleetside L33 5.3/4l65e .................__
............._____l __\__ ..............l_(O)_ l___(O)] |
11-10-2009, 02:32 AM | #2 |
Re: What is Recomended for cleaning out Engine?
Does the oil on the dipstick look milky/watery or like a nasty milkshake ? You may have a water leak from the head gasket or the intake manifold into the engine.
1977 GMC Sierra Grande |
11-10-2009, 02:37 AM | #3 |
the dip stick is clear. the milky residue that came up on the rocker arms wasn't very thick at all, i would say mostly oil
11-10-2009, 08:52 AM | #4 |
My engine had this problem and I dropped the pan and cleaned it out and while the pan was off I sprayed the rotating assembley with brake cleaner.
***My 84 short bed build up***** http://67-72chevytrucks.com/vboard/s...68#post3481968 |
11-10-2009, 09:42 AM | #5 |
Squarebody Aficionado
that will be the easiest and safest thing to do it might take a lil under 30 min to drop the pan and like that your sure whats sitting at the bottom of it.
11-10-2009, 02:25 PM | #6 |
isn't it going to be tough with the cross member in the way? and what would be the best way to hold the gasket in place?
11-10-2009, 03:54 PM | #7 |
Master Hater
If its just a little bit and the oil as a whole isn't milky looking , just drive it for a few days then change the oil. no need to drop the pan. Getting the oil up to operating temp will burn off any little bit of water in the oil.
