Old 11-10-2009, 12:13 PM   #1
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Need info
I need some info on a 98' Z71. 10b rear. It has gone through 3 rearends. $1200 each. He keeps buying new GM rears, the hole housing and all. Whats wrong? I told him to get a limited slip posi unit and put it in instead of keep buying $1200 rears. He said the ring and pinion teeth just shattered and ground and killed everything internal. What rears will fit? He needs 3:42. I told him if he gets an aftermarket posi and ring and pinion it'll last forever and save him $1200 every few years. All info and links very appreciated.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 11-10-2009, 12:59 PM   #2
ghettoluxury
ghettoluxury's Avatar
Re: Need info
A 14 bolt semi float from 88-98 3/4 ton will be a direct replacement. they are still 6 lug and can be found with 3:42's.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 11-10-2009, 01:06 PM   #3
thirdstreettito
Resident of Here
Re: Need info
I meant something easy to find. It hard to find 6-lug 3/4t rears, let alone a 14b. Thanks though.
~Bradley~
Miss having a truck
Old 11-10-2009, 01:10 PM   #4
tallhoedude
ROCKWELL 5 TON CLUB !!
tallhoedude's Avatar
Re: Need info
whats some more info on the truck?
hp?
tire size?
thats pretty uncommon from what ive seen unless theyre being abused.
i have seen several of those light 3/4 truck rears around pretty cheap too.
1970 K5 "ON THE ROCKS" PROJECT:500hp 6.0 fuel injected. 2wd sm465 trans,t136 2.5 ton transfercase,5ton rockwells with 9.34 gears,custom wheel disc brakes,full hydro steering20+" OF LIFT AND 67/35/25's..67" tall TRACTOR TIRES.."THE MUD SLUT!!"
MY BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=221935
1997 TAHOE,SAS D60 14B,5:13 DISC BRAKES,CROSSOVER STEER,HYDRO ASSIST,42 IROKS
HINT:NEW NAME "K5ontheROCKS!"
tallhoedude is offline   Reply With Quote
Old 11-10-2009, 01:10 PM   #5
ghettoluxury
Re: Need info
No it's not. I have that exact axle in my driveway and cant get rid of it.
Old 11-10-2009, 01:16 PM   #6
tallhoedude
Re: Need info
the destroyed 10bolt or the light 3/4 ton axle???
sorry ,confused?
MY BUILD THREAD:
Old 11-10-2009, 02:03 PM   #7
ghettoluxury
Re: Need info
the 14bolt semi float
Old 11-10-2009, 03:19 PM   #8
dammitmitchell
the pollock
dammitmitchell's Avatar
Re: Need info
yeah i caouldnt get rid of my semi float so i scrapped it
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 11-11-2009, 12:37 AM   #9
thirdstreettito
Resident of Here
Re: Need info
He has 245/85/r16 I believe, stock 350. He doesnt abuse it, they just keep dieing. I havent seen and light 3/4t rears around here at all, here its either 8-lug 3/4t and 1t or 6-lug 1/2t.
~Bradley~
Miss having a truck
Old 11-12-2009, 11:19 AM   #10
thirdstreettito
Resident of Here
Re: Need info
Bump
~Bradley~
Miss having a truck
Old 11-13-2009, 09:11 AM   #11
Re: Need info
I`d look a little harder for a light duty 3/4t 14-bolt.That`s your solution and they are plentiful everywhere.It`s odd what`s happening because the rear should last to the junk yard with standard tires and no abuse.If it was the same rear/housing it would be easier to figure.But,a whole new assembly each time?Why would an aftermarket posi make it last forever?The 6-lug 3/4t rears that are hard to find are the Dana 60s from 67-72.GM started building the light 3/4t 6-lugs in`88 and they were more common than the HD 8-lug option in the early years.
