11-12-2009, 10:13 PM | #1 |
5 Speed Swap Question
I was wondering how hard it would be to swap in a 5 spd from an 02/03 3500 to an 82 3/4ton with a granny low 4 spd?
I figure the trans should hold up since it came from a 1 ton but what I am wondering is how difficult it might be to swap in the later trans. I found the 5 spd for 450 bucks and would love to get the overdrive since I have a few long haul trips I need to make with the 82. Any ideas or suggestions would be appreciated. Paul
2 Chevy Monzas and 5 Buick Skyhawks 1 53 Chevy Truck....1 69 Chevy C/10.....1 72 Chevy C/10....1 69 Chevy C/20 1 83 Chevy El Camino SS 1 98 Chevy Tahoe 2dr 4x4 ....1 02 Jeep Liberty Limited In loving memory...Dad: David Nelson (5/24/38-2/14/2007) and Mom: Betty Nelson (3/6/51-1/5/2010) |
11-12-2009, 10:20 PM | #2 |
Re: 5 Speed Swap Question
i know for sure you would have to make a custom cross member, and get a different length driveshaft. maybe cut a bigger hole in the floor and theres probably somewiring connections you need but im not for sure. i dont think i have ever heard ofanyone doing this.. it would be cool though.. if its possible
"I'll keep my guns, money, and freedom. You can keep the "change" |
11-12-2009, 10:44 PM | #3 |
Considering how many trips I need to make to go get the rest of my stuff..... it might be worth the effort especially with gas starting to yo-yo again.
I take it that the clutch will be hydraulic since I found some other threads on a 5spd on the board with talk of the hyd. clutch. That might not be such a problem. My concern has to deal with the bolt pattern for the 02/03 truck. I tried to get some info on what the trans came out of since it was just sitting on the floor and I got very little. Came from the 02 ( might have been 03 ) truck with a v8 and that it was a 3500. This might sound dumb but is the bell housing bolt pattern the same with a 350 in the 82 verses the new 02 model?? As far as the driveshaft that shouldn't be too much trouble although I would have to find a place close by. ( Lived here just over a year and still trying to locate all the goody store/places in this area ). Right now I see the bellhousing bolt pattern, clutch, and cross member being the biggest problems. Although the clutch might not be quite so bad. Hmmmmmm...
11-12-2009, 10:51 PM | #4 |
achevy trans bolt pattern is a chevy trans bolt pattern. it will bolt up. the cross member would be the least of my worries.im not too farmiliar with these transmisions and i dont know what kind of electronics you need to run it right... and the clutch is another story. i really have no idea on that.. anybody know if this is gonna work? i think it would be awesome to see
11-12-2009, 11:08 PM | #5 |
Suggest Googling "nv4500" and start reading. As your trans came from a 1 ton model then you should have a NV 4500.
A couple of years ago I assisted with a NV 4500 install into a 70's era one ton replacing the SN 465 4-speed. We installed the hydraulic master cylinder, line and slave cylinder from an early 90's one ton, (I recall using the same cross-member) and had to modify the driveshaft....actually we had a new one built since it was a few dollars more than replacing the carrier bearing and U-joints. We did not have functioning speedometer since the original truck had a cable activated speedometer vs. the VSS module on the new trans. However I recall the bellhousing for the NV 4500 is unique since the trans to bell housing bolt spacing is unique. However the b/h bolted right to the SBC motor. If you go this route, take photos and good notes and post your results. Update: I checked with the guy I assisted and he modified the crossmember prior to my involvement. Last edited by dan76; 11-14-2009 at 03:39 PM. Reason: clarification |
11-12-2009, 11:09 PM | #6 |
Resident of Here
Go with a NV4500. No electronics, just crossmember, driveshaft, and hyd/ clutch to deal with.
~Bradley~ 2004 Black GTO LS2/T56 too much to list Miss having a truck |
11-12-2009, 11:25 PM | #7 |
I didn't recall any electronics ( no wires ) from the trans but I do remember seeing a line coming out of the top of the bellhousing I think ( can't remember exact location but can go look again ).
I will run by and check again tomorrow. I will see if I can get some pics of the trans. It is sitting out on the floor so shouldn't be a problem. So far this looks some what like a do-able project. Paul
11-12-2009, 11:29 PM | #8 |
Jonny
Yes electronics, they use a VSS instead of a cable driven speedometer. I have heard that some where in the 88-91 era they put electronic speedos in our trucks so you should be able to use in of those.
1966 C30, Cummins, stacks, and a flat bed in progress... "Honor.....simply put, A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it." -AEC Hundley USNR |
11-12-2009, 11:37 PM | #9 |
well if the only wiring needed is for the speedo, and everything else is pretty straight forward, all that leaves is the clutch..
11-12-2009, 11:42 PM | #10 |
Was there any other trans in the 02/03 trucks or just the 4500?
Either way I will go back by there tomorrow and go back over the trans again and see whats what. I doubt that both trans will be gone since there was 2 sitting there together. One still had a bell housing and fork as well as the shifter. It was the more complete of the two so that is the one I am more interested in. I will still take pics tomorrow and post back with what I find out. Paul
11-13-2009, 06:47 PM | #11 | |
Moderator
GM used VSS speedometers for all years. Dodge used speedo gears for most of the `90s 2wd trannies. If you have a 4x4 then the speedo drive is not in the tranny. Hybrid GM/Dodge NV4500s have been built by swapping the input shafts and bellhousings. So you need to check everything (input/output spline counts, input shaft lengths & diameters) to verify what you are looking at. Spline counts and input shaft measurements are in this article NV4500 Wiki |
11-14-2009, 03:34 AM | #12 |
Well I know it had a fork that I can be 99% sure about. I'm not 100% sure that the info on what it came out of it correct but thats all I got.
Today ended up being a bust so hopefully tomorrow if the place is open I will go check it out. I will get pics and take down any numbers I can find. If no luck in tomorrow then hopefully the first of the week or their next day open I will gather up what I can. Thanks again for the help and links. Paul
11-12-2009, 11:57 PM | #13 |
check your spline count on the transmission just to make sure. Those LS motors are a whole new animal as far as engines go.
11-13-2009, 12:32 AM | #14 |
Prior to returning to check the transmissions, print this list and use it to determine where the trans came from.
http://www.nv4500.com/newsdesk_info....newsdesk_id/31 |
11-13-2009, 12:55 AM | #15 |
I have car A.D.D.
dan76: that is a great link. Thanks for that info. I think that will be handy for a lot of us at some point.
-Gerald Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace. 61 GMC Suburban SOLD The 86 build thread SOLD Are you a Colorado member?Click here. |
