Old 11-12-2009, 11:15 PM   #1
texassquarebodies
Truck Nut
texassquarebodies's Avatar
Suburban drop help....
I have a 1987 suburban I am lowering. I already put drop spindles in the front and shackles in the rear. Sits about level. I think I want 2" lower. I want to drop the rear some more but do not a flip kit or pull a leaf out or dropped leaves.. Anyone moved your front hanger upwards to drop the rear?? Does anyone make a drop hanger for a burb? I got the front covered. Ideas?
Tony Kee
Texas Square Bodies
texassquarebodies is offline   Reply With Quote
Old 11-13-2009, 02:48 AM   #2
SBTork
Garage wrench
SBTork's Avatar
Re: Suburban drop help....
I too would like to know....
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 11-13-2009, 08:57 AM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
Tony= I haven't seen it done on a Burb, but you can move front and rear hanger up. You will need to pull them and cut the top off a bit to clear, drill new holes, etc.
If you just move the front hanger, you are probably going to have pinion angle issues. I don't know if degree shims will compensate enough or not.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-13-2009, 07:53 PM   #4
texassquarebodies
Truck Nut
Ken, I have thought about doing that but, that dam body mount is smack dab in the middle of that hanger. I am probably going to cut it and move it up...the hanger that is. Going to trim the body mount also.
Tony Kee
Texas Square Bodies
Old 11-13-2009, 10:55 PM   #5
87 dually burb
my short bus
87 dually burb's Avatar
you can do a 2" shackle if you mess with the filler hoses some
may be best bet and easy
**90 burb**bagged,shaved**(about done)*********
**91 burb**stock worker for now****************
*********only squares for me******************
87 dually burb is offline   Reply With Quote
Old 11-14-2009, 01:48 PM   #6
texassquarebodies
Truck Nut
Already put drop shackles on it. Needs to go a little lower.
Tony Kee
Texas Square Bodies
Old 11-15-2009, 12:05 PM   #7
tobiahr
tobiahr's Avatar
Return to stock shackles and install a flip instead? you should get about 5 inch drop with a flip and it would need almost no fab work.
tobiahr is offline   Reply With Quote
Old 11-16-2009, 12:17 PM   #8
justpball
justpball's Avatar
what he said, and if you have welding skills just buy a set of the axle saddles and weld them on the bottom of the axle and it is a cheap flip!
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline   Reply With Quote
Old 11-16-2009, 09:34 PM   #9
texassquarebodies
Truck Nut
I put a flip kit on it and then took it off. 6" flip plus saggy suburban rear springs...I didn't want it that low. Going to move the front hanger up sometime soon and see what happens
Tony Kee
Texas Square Bodies
