Old 11-13-2009, 07:19 PM   #1
78-5.3
78-5.3's Avatar
3" spindles
ok i ended up cutting 1 1/2 coil and used 3" spindles and got the truck 27 3/4" from the ground to the lip im happy with the way it looks my question is what happens with the brake line to the caliper mine has a bend and it fouls i has to straighten it to clear any ideas
78-5.3 is offline   Reply With Quote
Old 11-13-2009, 08:00 PM   #2
menace121978
menace121978's Avatar
Re: 3" spindles
wheres the pics man??
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 11-13-2009, 08:03 PM   #3
3r!c84
Badass
3r!c84's Avatar
Re: 3" spindles
i just bent the line down a little to clear the spindle and i raped a thicker tubing arond the rubber braker line where its close to the upper nut
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 11-13-2009, 08:10 PM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: 3" spindles
I just bend the hard section at the end of the line to clear the ball joint nut. Never had any issues after that.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 11-13-2009, 08:16 PM   #5
3r!c84
Badass
3r!c84's Avatar
Re: 3" spindles
can i bend it that far with out braking the steel part of the line?
-00 Saturn 5spd
1/4:13:90
Old 11-13-2009, 08:22 PM   #6
Tx Firefighter
Re: 3" spindles
I've always been able to. I try and bend it against something roundish to give it a smooth radius so it's less likely to kink as if you did it by hand.
Old 11-13-2009, 08:26 PM   #7
3r!c84
Badass
3r!c84's Avatar
Re: 3" spindles
like what? i grabed it with plyers and pulled it alittle be for
-00 Saturn 5spd
1/4:13:90
Old 11-13-2009, 08:41 PM   #8
Tx Firefighter
Re: 3" spindles
Use whatever is handy. What I mean is, if you just tweak the line without care, it will likely kink at the end of the line where it bolts to the caliper. You need to make sure and tweak it a little at a time over the first inch or so of the hard line section. If you have strong hands, you can just curve it a bit with your hands.
Old 11-13-2009, 09:32 PM   #9
flatblkserria82
Re: 3" spindles
i use an openend wrench and bent mine just be sure not to break or kink it
flatblkserria82 is offline   Reply With Quote
Old 11-13-2009, 11:23 PM   #10
78-5.3
78-5.3's Avatar
Re: 3" spindles
i rested a piece of wood on top of the rotor and with another piece on top tap it flat !! worked slick!!!!!!!!
Old 11-14-2009, 09:26 AM   #11
westofb
I really hate wet sanding!
westofb's Avatar
Re: 3" spindles
I have always had good luck just tapping on it wit a small hammer near the hose end of line, the key is to just strike it easy and bend it slowly. Of course watching carefully that the line does not kink, by tapping it easy with the hammer you can see it start to kink (if chooses too) and stop before it becomes a problem.
Kevin, if you can bend those lines with your hands, what have you been doing in your spare time......LOL.
Jeff,
68 C-10
75 C-20, now a C-10!
10 F-150
westofb is offline   Reply With Quote
Old 11-14-2009, 06:51 PM   #12
78-5.3
78-5.3's Avatar
Re: 3" spindles
what about these there off a c30 one ton i brought them 5 years ago i just thought about them wouldnt these work????
