11-14-2009, 12:23 AM | #1 |
Who's got steelies?
Suburban A-pillar
Has anyone tried running speaker wires up the driver's side a-pillar with the other wires already there? How hard was it? The asm. manual makes it seem like they are 1/2" dia holes, so I think their would be room.... but I could be pretty darn wrong too. Any help?
1969 C10 LWB W/ 250 I6 & 3spd 1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver. 1975 Chevelle Malibu Classic Coupe 350/th350 mint green 1970 C20 Suburban 350/700R4 4.10 gearing green & white 1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver 1983 GMC 1500 Sierra 305/SM465 2.73 rear end How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
11-14-2009, 01:05 AM | #2 |
70 Chevrolet=Obsession
Re: Suburban A-pillar
There is an item called "fish tape" which installers use to get wire through walls. I don't know the answer specifically but I'll bet 2 things. 1 It's a real bear. 2 Longhornman probably knows.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke! IT'S NOT EASY BEING GREEN! -Kermit the frog 1970 Chevrolet C-10 Longbed Stepside : 350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes) 1996 Toyota Corolla (Parts runner) |
11-14-2009, 01:36 AM | #3 |
its all about the +6 inches
LOL!
I'll say this much, I tried running the single wire through that hole on my longhorn for the marker/ID lights... I gave up after a good hr or two of fighting and cussing. |
11-14-2009, 01:58 AM | #4 |
The PO of my burb had a radio antenna ran up the passenger side and over to the center of the roof (I left it there) and some other wires ran up the driver side...so its possible. I can't remember if the rear A/C wiring runs up the driver side or if it comes up the rear driver quarter...I think up the A pillar.....?
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold 1972 C10 5.3L/4L60E 12bolt 5Lug - Sold 1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!! 1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold 1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold 1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold) 2003 K2500HD 8.1/Allison1000/NP263 |
11-14-2009, 10:52 AM | #5 |
The wire for my dome light goes up through the driver's A Pillar.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
11-14-2009, 02:56 PM | #6 |
Who's got steelies?
So are there already holes on the pass side?
This sounds like its going to be a total PITA so for those of you who have mounted speakers to your burbs ceiling, where did you run the wires? Thanks!
11-14-2009, 05:14 PM | #7 |
What?
I've done it, and it wasn't as hard as everyone says for me.
What I did was take apart the rear harness plug, tape it all up with a fish wire and pull it through. Then attach your additional wires to the rear wire harness tape bundle, and pull it all back through the hole. Re-assemble the rear harness plug, making sure you put it back together exactly as it was before you took it apart.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
11-14-2009, 11:06 PM | #8 |
I ran a wire up through there for a map light in my Panel. It took a few tries, but it wasn't to difficult.
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
11-15-2009, 12:00 AM | #9 |
I ran wires in both my A-pillars. Had to drill on the PS (way up under the dash and not visible).
11-15-2009, 04:14 AM | #10 |
I had a V-8
I have done it on the driver side. I used a piece of 14-16ga steel wire, dropped it down from the top, grabbed it when it passed the hole in the kickpanel, pulled it through, taped my wires to it and carefully pulled it back up.
Was not bad at all.
1972 K20 Suburban, 5.9L Cummins, Banks Power Pack, NV4500HD, NP205, H.A.D., D60/14FF ARB Link To Build: HERE. |
11-15-2009, 11:53 AM | #11 |
Who's got steelies?
Thanks for the replies!
So Frizzle Fry, yours already had the hole at the top of the pillar? Pritch, where did you get your map light?
11-15-2009, 01:06 PM | #12 |
I hate to admit it, but it's from a '89 F*rd F-250 (ducking tomatoes).
