Old 11-14-2009, 07:55 PM   #1
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
71-72 1/2t vs 3/4t power booster setups
What can y'all tell me about the differences in the booster setups 1/2 vs 3/4 ton? What parts are common between the two?
Basically, what I want to know is could I use a 3/4 ton master cylinder with the 1/2 ton booster and bell crank/bracket that bolts to the firewall?
Thanks!
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 11-15-2009, 12:15 AM   #2
JimKshortstep4x4
Re: 71-72 1/2t vs 3/4t power booster setups
I believe that there is a problem between the booster and master cylinder if you try to use a 3/4 ton MC with a 1/2 ton booster. At least all of the ones that I have seen will not interchange.
The mounts to the firewall are the same.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 11-15-2009, 11:56 AM   #3
oldgold70c10
Who's got steelies?
Jim
Thanks, that's exactly what I needeed to know!
My Truck Page
My Youtube Channel
Old 11-15-2009, 11:04 PM   #4
screamin_c10
I dun gradjiated collij!!!
screamin_c10's Avatar
Jim
What is the difference? I ask because I have a 1/2 ton disk front end I will be swapping under my 68 C20 and thought the power brake 1/2 ton M/C was a bolt on to the C20 booster....Is it a piston to plunger thing, the bolt pattern etc?
Any further info would be helpful...sorry for the hijack
screamin_c10 is offline   Reply With Quote
