11-15-2009, 03:03 PM | #1 |
Junior Member
Msd hei?
I just finished putting an MSD Street Fire dist. in my son's '67. Stock 260 hp crate motor, Edelbrock performer carb and intake. Set initial advance at 10 degrees, total centrifigul was only 29 all in at 3000 rpm. I adjusted the vacum advance four turns out for a total of 51 degrees all in at 3000. It starts and runs well but I am a little curious that the total centrifigul is only 29. Any opinions?
63 C10 70 Coronet R/T 67 C10 70 Dart Swinger 71 K10 |
11-16-2009, 10:10 PM | #2 |
Re: Msd hei?
Id be more concerned w/ total than initial, can it be recurved?
11-18-2009, 12:00 AM | #3 |
Re: Msd hei?
do you relize that at 51* the timing mark is at about 10 oclock on the passenger side?
11-16-2009, 11:34 PM | #4 |
Re: Msd hei?
51 total is way to much, go for 36-38 imo...
11-16-2009, 11:58 PM | #5 |
70 Chevrolet=Obsession
Re: Msd hei?
A few months ago I installed a MSD Streetfire on my 350. I wanted it timed right so I took it to a guy who knows what he's doing. It ended up being 16 degrees initial with a total of 36 degrees. Truck starts real easy and jumps good when I give it the gas. I don't know how many turns out he set my vacuum advance but you do have 6 more turns available. BTW, I have an RV-1 cam.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke! IT'S NOT EASY BEING GREEN! -Kermit the frog 1970 Chevrolet C-10 Longbed Stepside : 350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes) 1996 Toyota Corolla (Parts runner) Last edited by unclewatts; 11-17-2009 at 12:01 AM. |
11-17-2009, 12:20 AM | #6 | |
Re: Msd hei?
Sounds like your in the ball park 29 centrifical + 10 intial =39 total if your connected to full manifold vacuum the additional advance will only come in when there is no load on the engine. Here is some good reading. There is also a good sticky in the engine and drivetrain section by billa.
1965 GMC shortwide big window 1969 Chevy C20 long (for now) 2005 Silverado 2500HD Crew Cab Quote:
11-17-2009, 01:46 AM | #7 |
Re: Msd hei?
holy hell 51* is insane. his compression must be 4:1.
that is almost a full plugwire ahead of the fire. Last edited by 2tons of fun; 11-17-2009 at 01:47 AM. |
11-17-2009, 09:12 PM | #8 |
Junior Member
Re: Msd hei?
51 is the total with the vacum line hooked up. 29 was total centrifigul. I might try putting a little more initial in it, it didn't crank hard when starting.
11-17-2009, 11:05 PM | #9 |
Re: Msd hei?
i dont think you understand, that much timing is going to fawk something up or you have something hooked up wrong.
11-17-2009, 11:14 PM | #10 | |
Re: Msd hei?
I misread the first post but 34*-36* initial + total mechanical is pretty much the sweet spot the vacuum advance number doesn't count towards total advance because full manifold vacuum drops out when engine is under a load
11-18-2009, 09:26 PM | #11 |
Junior Member
Re: Msd hei?
fixit-p, I read the articles you linked, they make a lot of sense. The MSD instructions said to hook to ported vacuum, I will try full manifold vacuum and go from there. Thanks for the help.
