Getting truck running after sitting for 10+yrs
Just bought a 67 c10 thats gonna be my second project truck
![]() so what would it need to get completly running im guessing atleast battery, oil/filter, flush gas tank/new gas filter, flush radiator just go ahead and change brake lines or bleed them? change gear oil? take out transmission and check over?? anything else im missing? thanks in advance!! Last edited by Mxracer202; 11-15-2009 at 05:38 PM. |
Re: Getting truck running after sitting for 10+yrs
im only 24 but a couple of old school guys i work with said if the motor is seized throw some deisel in the piston and it should break loose. might want to try
so what should I use to loosen the pistons
Automatic transmission fluid wd-40 diesel fuel PB Blaster JB-80? ???????? so I tried to get to the piston through the spark plugs but found out that my 13/16 wrench and 5/8 plug socket didnt work? now what how can i get to the piston easily Last edited by Mxracer202; 11-15-2009 at 10:57 PM. |
could i just pour SEAFOAM and let it sit in the pistons then try to break the crank loose with a breaker bar slowly?
ANYONE???????
58 Jeep willys pickup 67 K10 4x4- soon to be trail truck ![]() TROUBLE MAKER RACING ![]() "If you can't stand BEHIND our troops, please stand in FRONT of them." |
i did this with a boat motor. we pulled the pluds and filled the cylinder with atf. then let it sit for a week. then worker back and forth with a breaker bar on the crank
Pull the head off and soak the cylinders with a good penetrating oil for several days. When you can move it a little with a breaker bar. move it in the direction that will move the piston down in the cylinder or cylinder that will have rust showing on the walls. Crocus cloth it off using plenty of oil. Once you get the walls cleaned up it will move freely. If you force it without cleaning up the walls chances are you will break something. It doesn't take much rust, even in one cylinder, to stick an engine.
#7 | |
Hand Crafted C-10
![]() Join Date: Aug 2006
Did you get the plugs out? If not, could it be full of water? (hydrauliced)? |
Yea finally, It took me a while and a ton of PB blaster! they werent full of anything but rust all the way up and down the cylinder. so i put some PB blaster in and it still wont turn over, wont even budge. so ive opted for the spare, as soon as i get it off the stand and in the 67 the original is gettin a rebuild or sold.
![]() ![]() Join Date: Dec 1999
Any of what you listed are decent choices.
2008 Chevy HHR 1/2 panel. 1949 Chevy Panel truck(just sittin, waiting) Board member #6 |
any pictures of this 67 you speak of
Here are a few
![]() 100_0238 by Mxracer202, on Flickr ![]() 67 k10 original I6 by Mxracer202, on Flickr So ive just decided to swap motors for a little peace of mind.
58 Jeep willys pickup 67 K10 4x4- soon to be trail truck ![]() TROUBLE MAKER RACING ![]() "If you can't stand BEHIND our troops, please stand in FRONT of them." Last edited by Mxracer202; 02-27-2011 at 09:58 PM. |
