Old 11-17-2009, 11:38 AM   #1
burban90
tire size
how big of a tire can i fit on a 1990 gmc suburban 1500 2wd without lifting it? ive been told 31s will fit and ive been told 33s will fit as well but im not sure. it has 235/75/15 on it now
burban90 is offline   Reply With Quote
Old 11-17-2009, 10:06 PM   #2
tvblazer78
Low & Fast!
tvblazer78's Avatar
Re: tire size
Welcome to the site!!
I would think on a 2wd a 31 would be about all you can do, if you go with a 33 then you would have to do some kind of lift to make that work.
Hope that helps,
Trav
tvblazer78 is offline   Reply With Quote
Old 11-17-2009, 11:55 PM   #3
87 dually burb
my short bus
87 dually burb's Avatar
Re: tire size
this was when I bought it last year lots of room never rubbed or issue
31" at's
**90 burb**bagged,shaved**(about done)*********
**91 burb**stock worker for now****************
*********only squares for me******************
87 dually burb is offline   Reply With Quote
Old 11-18-2009, 02:33 PM   #4
husker33
Re: tire size
I have 33s on my blazer. All i had to do was Cut the back bottom lip off of the outer fender about 4 inches up using a cut-off. I have had absolutly no problems with this set up. Now if your going to be doing hard core mudding i dont recommend 33s without a lift. the inner fenders need no modifications. Just be sure to put a rust prohibitor on that fresh steel.
2008 Chrysler 300C
1984 Chevy K5 Blazer
husker33 is offline   Reply With Quote
