11-18-2009, 10:24 PM | #1 |
NOS SB Pulleys
Small block
2 groove lower crank pulley #3744043 outer crank pulley for PS #3751232 PS pump pulley #3993325 3 for $100 includes shipping
atheystruck@comcast.net 67 1/2 ton 4wd custom cab 72 1/2 ton 4wd super cheyenne 71 1/2 BB super cheyenne shortbed |
11-30-2009, 08:18 PM | #2 |
Re: NOS SB Pulleys
ttt
11-30-2009, 08:39 PM | #3 |
Re: NOS SB Pulleys
I am going to put power steering on my 67. It has a stock 283 non a/c. I bought the pump and bracket but I need the crank pulley. I have researched the pulley some at the Chevy dealer and came up with the 3744043 2 grove. Are you saying that I need the 3751232 add on pulley for PS?
Thanks Nate
Nate 1967 short fleet Project Blue Goose 'If it don't bounce back... heeheehee you go hungry!" Blues Brothers |
11-30-2009, 09:30 PM | #4 |
Re: NOS SB Pulleys
all of the original setups for the 67-72 SB that I have seen had a 2 pc crank pulley for the PS. PS was a seperate pulley I may be wrong I am sure someone on here can let us know.
12-01-2009, 11:26 PM | #5 |
K5drive
Re: NOS SB Pulleys
You are correct the add on pully is for an ac truck. But the crank shaft pully will dictate that you need to run the orig power steering and water pumps wich is a short shaft waterpump and you can buy the water pump pulley easily
12-01-2009, 11:34 PM | #6 |
K5drive
Re: NOS SB Pulleys
Guess we should clarify that the crank pully your looking for is shallow the 2groves are right next to the harmonic balancer. Alot of the ones I noticed are away from the balancer about 1 1/2 to 1 3/4 inches .Those are the ones you dont want
12-01-2009, 11:47 PM | #7 | |
Re: NOS SB Pulleys
My research has been conflicting but has a single grove plus a double grove pulley bolted together. So one grove will not be used in the middle. My PS pump pulley part # is 3993325
12-04-2009, 06:12 PM | #8 |
Re: NOS SB Pulleys
I will try to post some pics tomorrow. I can split them up. I am sure these are the ones you are needing though
12-05-2009, 05:42 PM | #9 |
Re: NOS SB Pulleys
I have misplaced the double outside pulley but have it somewhere. But this one is for an ac truck. The crank pulley is a single back one and this one goes on it for the power steering. the one on the left is the add on pulley the RH one is used.
12-05-2009, 05:47 PM | #10 |
Re: NOS SB Pulleys
picture of pump pulley
12-05-2009, 09:01 PM | #11 | |
Re: NOS SB Pulleys
Thanks Nate I am talking about the 3751232 pulley and the matching flat one with the locators.
Nate 1967 short fleet Project Blue Goose 'If it don't bounce back... heeheehee you go hungry!" Blues Brothers Last edited by nds1968; 12-05-2009 at 09:36 PM. Reason: adding info. |
12-05-2009, 06:28 PM | #12 |
Re: NOS SB Pulleys
I do not think NDS1968 wants the deep dish pulley. If he has a single crank pulley ( and no ac) he will need a single shallow pulley that will bolt onto the existing single crank pulley as it has two raised locators on it that fit in holes on the new pulley. He will use the same three bolts that hold the single pulley to bolt both on the harmonic balancer. The PS pulley goes on the pump with the groove closest to the pump housing.
12-05-2009, 07:11 PM | #13 |
Re: NOS SB Pulleys
that is what this pulley is
12-05-2009, 10:44 PM | #14 |
Re: NOS SB Pulleys
will do $45 + ship
12-05-2009, 10:53 PM | #15 |
Re: NOS SB Pulleys
06-03-2011, 11:58 AM | #16 |
Re: NOS SB Pulleys
Forgive me for bringing up an old thread but I was wondering if you still have the power steering pulley #3993325?
355,vortec heads, Doug Herbert cam, Performer intake, 750 Holley, Hooker Comps, 2 1/2 duals w/Aero Chambers, 2500 stall and 3.73 posi. |
06-03-2011, 09:46 PM | #17 |
Re: NOS SB Pulleys
sorry sold
06-04-2011, 12:21 AM | #18 |
Re: NOS SB Pulleys
Story of my life, day late and a dollar short lol. Thanks for the reply.
