Old 11-20-2009, 03:58 PM   #1
olred68
olred68's Avatar
Drop Spindles vs Drop springs
I want to convert my 68 to 5 lug and I have donor truck thats 5lug and should I just use the spindles thats on my donor truck and buy drop springs or should I just buy drop spindles? I am looking to go 2 1/2 in the front and 4 in the rear just not sure what would be my best bet Thanks Brandon
Brandon
olred68 is offline   Reply With Quote
Old 11-20-2009, 04:04 PM   #2
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: Drop Spindles vs Drop springs
Brandon, I would recommend the drop spindles because in my opinion anything over a 2" front drop spring will affect the front suspensions geometry. Just my opinion....
I know the spindles will cost you more, but in the end it will be worth it. Besides, after you get to 2.5/4 you will always want to go lower and then you'll need spindles anyway.
I'd highly recommend checking with ECE (Early Classic Enterprises) as they are one of the best companies on the market today for products for the 63-72 suspensions. www.earlyclassic.com
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 11-20-2009, 04:25 PM   #3
vegaschevy
I second the purchase of drop spindles. THen if you decide to go lower a quick spring change and you are ready to go.
I got my drop spindles from Nate at Porterbilt. THey were McGaughy drop spindles and less then 240 shipped to my door. They also use the OEM year steering components as I purchased new Moog steering stuff and they mounted right up
vegaschevy is offline   Reply With Quote
Old 11-20-2009, 08:51 PM   #4
olred68
olred68's Avatar
ok guys thanks for the help I guess I need to do some shopping
Brandon
Old 11-20-2009, 10:00 PM   #5
big mike71
big mike71's Avatar
Hey Nate how much drop do you have and how wide are your front wheels.
I'm not as good as I once was, But I'm as good once as I ever was.
big mike71 is offline   Reply With Quote
Old 11-20-2009, 09:54 PM   #6
OARNGESI
OARNGESI's Avatar
Also with drop spindles you wont have to get shorter shocks
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 11-21-2009, 12:16 AM   #7
unclewatts
70 Chevrolet=Obsession
unclewatts's Avatar
As long as you're gonna switch to 5 lug, why not get some drop spindles for a 71-72 and convert to disk brakes at the same time?
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke!
IT'S NOT EASY BEING GREEN! -Kermit the frog
1970 Chevrolet C-10 Longbed Stepside :
350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes)
1996 Toyota Corolla (Parts runner)
unclewatts is offline   Reply With Quote
Old 11-21-2009, 12:22 AM   #8
OARNGESI
OARNGESI's Avatar
Originally Posted by unclewatts View Post
as long as you're gonna switch to 5 lug, why not get some drop spindles for a 71-72 and convert to disk brakes at the same time?
wasnt that his plan
70 SWB STEPSIDE
70 BLAZER
09 challenger
Old 11-21-2009, 03:58 AM   #9
68custom396
Just a thought but in most cases a 15in wheel wont work with a spindle you need a 17 or bigger. Just something to think about, that will also raise the cost of your project
68custom396 is offline   Reply With Quote
Old 11-21-2009, 08:09 AM   #10
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
He already has a donor truck for disc brakes. He needs to buy spindles for his donor truck year. 71-72 has nothing to do with it in this case.
Flat wrong. 15 inch wheels work fine with drop spindles. The only issue can be if he chooses 3 inch drop spindles, they require slight clearancing of the control arms if the back space is too great. I've lost count of how many trucks I've owned with drop spindles and 15 inch wheels.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 12-02-2009, 02:17 AM   #11
slimneverdies
slimneverdies's Avatar
How is this clearance issue resolved? I plan on running 3" spins on my 15x10 corvette rally wheels. By the way its a 86 1/2 ton
Long live SLIM
At least try to buy American
slimneverdies is offline   Reply With Quote
Old 11-21-2009, 08:52 AM   #12
lolife99
67-72 parts collector,…
lolife99's Avatar
That might be true on some of the '99-up trucks,... but it's not the case with any spindle made for the trucks from '63-'98.
Keith
Convert to disc brakes.
Old 11-21-2009, 11:09 PM   #13
olred68
olred68's Avatar
Whats the best company to deal with for the spindles or does anyone have any for sale I am also looking for 4" drop in the back
Brandon
Old 11-23-2009, 09:43 AM   #14
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Mike, on my truck I'm running 4.5/6" (2.5" drop spindles w/ 2" front drop springs, and 6" rear drop springs - all ECE), and I'm running 15x7 6-lug ralleys with 235 75R15's on the front and the same tire setup on the rear on a 15x8.
Just continuing what Keith and Kevin each stated... ECE all the way!
-Nate
Old 11-21-2009, 11:15 PM   #15
lolife99
lolife99's Avatar
Hands down,... ECE. (Early Classic Enterprises).
Keith
Old 11-22-2009, 07:41 AM   #16
Tx Firefighter
Yep, ECE is your place.
