11-24-2009, 01:15 AM | #1 |
67-68 rear ends
what rear ends came stock in 67-68?
64 buick skylark 65 buick skylark 67 chevy 2wd Lb 68 2w Lb 05 chevy colbalt |
11-24-2009, 01:17 AM | #2 |
Recovering 67-72 Addict
Re: 67-68 rear ends
6 lug 12 bolt
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt. "Friends call me cruzer cuz I like fast cars and fast women" |
11-24-2009, 01:19 AM | #3 |
Re: 67-68 rear ends
was there any othere options
11-24-2009, 01:22 AM | #4 |
Re: 67-68 rear ends
I guess I should have asked if it was a 1/2 or 3/4 ton. If a 3/4 ton then it should have an HO52 full floater.
11-24-2009, 01:27 AM | #5 |
Re: 67-68 rear ends
2wd cst c20 i think
11-24-2009, 01:30 AM | #6 |
Re: 67-68 rear ends
Okay, should be a corporate HO52 then unless changed in the last 40 years. If a leaf spring truck then there is a chance that it could be a Dana 60.
11-24-2009, 01:34 AM | #7 |
Re: 67-68 rear ends
this is the one that came out
11-24-2009, 01:36 AM | #8 |
Re: 67-68 rear ends
If that is an 8 lugger than I would say that is a Dana 60.
11-24-2009, 01:39 AM | #9 |
Re: 67-68 rear ends
6 lug
11-24-2009, 02:05 AM | #10 |
Re: 67-68 rear ends
Hmmm, 6 lug in a C20? 6 lugs implies 1/2 ton or C10. Should be a 12 bolt or maybe a Dana 44. Need to see the rear cover to ID.
11-24-2009, 02:09 AM | #11 |
Re: 67-68 rear ends
well i know its not a 12 bolt
11-24-2009, 02:11 AM | #12 |
Re: 67-68 rear ends
did chevy ever put a dana 44 in a 67 -68 truck
11-24-2009, 02:15 AM | #13 |
Its always something!
Re: 67-68 rear ends
I think they did in some of the leaf spring trucks. Is it a 10 bolt?
79 p10 stepvan 72 Short Fleetside 72 Suburban 67 GMC One Ton Flatbed 64 Short Fleetside 57 Chevy 2DR Hard Top 57 Chevy 2dr wagon 65 f*** short fleet 63 C 60 Flatbed Member of the patina club Last edited by shaneschevys; 11-24-2009 at 02:17 AM. |
11-24-2009, 02:20 AM | #14 |
Re: 67-68 rear ends
its coil
11-24-2009, 02:25 AM | #15 |
Re: 67-68 rear ends
I guess they could have put them in coil spring trucks. I have always seen them in leaf spring trucks.
79 p10 stepvan 72 Short Fleetside 72 Suburban 67 GMC One Ton Flatbed 64 Short Fleetside 57 Chevy 2DR Hard Top 57 Chevy 2dr wagon 65 f*** short fleet 63 C 60 Flatbed Member of the patina club |
11-24-2009, 02:25 AM | #16 |
Re: 67-68 rear ends
There were D44 put in these trucks. I personally have not seen one but have seen them pop up on this board several times. It is possible that a 6 lug D60 was swapped in later. On the dana's you can usually find a casting number in the webbing. Look for 44 or 60. If you had a picture of the cover we could at least ID if it is a dana.
11-24-2009, 08:00 PM | #17 |
Re: 67-68 rear ends
[ATTACH][/ATTACH] is this what you were talking about or one of the othere numbers
11-24-2009, 08:55 PM | #18 |
Re: 67-68 rear ends
Looks like a Dana 60. My D-60 is 6 lug, but most are 8 lug. An original C20 would have 8 lugs every time.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
11-24-2009, 09:41 PM | #19 |
What?
Re: 67-68 rear ends
I've only seen D-44's up front.
(A D-44 is my front axle)
Chris 1968 K20 Suburban 1972 K10 LWB PU |
11-24-2009, 11:39 PM | #20 |
Re: 67-68 rear ends
mine had a 6 lug 10 bolt when i got mine, but not a dana 44. but now it has a 71-72 5 lug 12 bolt, with 76 c10 rear drum brakes on it
11-25-2009, 12:28 AM | #21 |
Re: 67-68 rear ends
Definitely a Dana and based on the casting number it looks like a D-60. Here is a link to another reference to this axle:
http://67-72chevytrucks.com/vboard/s....php?p=3615814
11-25-2009, 12:54 AM | #22 |
Re: 67-68 rear ends
thanks that was way use full so dose any one know what all the numbers stand for on the back
64 buick skylark 65 buick skylark 67 chevy 2wd Lb 68 2w Lb 05 chevy colbalt Last edited by trukindud; 11-25-2009 at 01:21 AM. Reason: gramer |
11-25-2009, 02:37 AM | #23 |
Re: 67-68 rear ends
To get all the info about the dana 60 go to pirate4x4.com and look it up. They have everything listed. I have one of these out of a dodge and am upgrading my corporate 10 bolt in my 88 blazer. Those damn 38.5" tires have a way of destroying 1/2 ton axles. If you need the link to the d60 page let me know and ill look up the link in my bookmarks.
11-25-2009, 01:59 PM | #24 | |
Re: 67-68 rear ends
11-25-2009, 10:30 AM | #25 |
Re: 67-68 rear ends
Its a dana 60 for sure, there have been a few that popped up here but I have never seen an option for this on the 67-72 trucks. Heres another truck on the boards with one http://67-72chevytrucks.com/vboard/s....php?p=3615814
