Old 11-24-2009, 09:43 PM   #1
tc187211
I6 to 350 swap on 84 c-10
I know somwone else has done this before! I am using the stock motor mounts on the crossmember from the inline 6. it almost matches up but i can only get one bolt through the motor mount and the other side is slightly higher and just running the bolt through the bracket for the mount. It there a trick? Do I need to flip one or both upside down or move them to the next set of holes? Any help would be great.
tc187211 is offline   Reply With Quote
Old 11-24-2009, 10:54 PM   #2
79SWBchevy
Re: I6 to 350 swap on 84 c-10
im actually about to do the same exact thing in the next few weeks. can you post up some pics of what you are talking about with the one side being slightly higher than the other?
i hope someone who has some expierence can chime in because i really need some info as well.
79SWBchevy is offline   Reply With Quote
Old 11-25-2009, 12:39 AM   #3
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
The perches will work only with specific I-6s.
First off, the motor mounts for the 292 cid 6 cylinder are staggered. That is to say, the right motor mount is about 3" further forward than the left motor mount. On the V-8 and the 230/250 I-6 they are even or straight across for each other.
Read this: http://www.persh.org/Pickup/perches.htm
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 11-25-2009, 01:06 AM   #4
79SWBchevy
thanks g chemist, the page about the perches helped alot.
what is the vin code to tell if i have a 292 or 250? from what i have read, it is most likely a 250, do you agree?
thanks
Old 11-25-2009, 02:43 AM   #5
gchemist
gchemist's Avatar
You can find casting numbers at www.mortec.com or http://www.73-87.com/chevy_ids/sbcid2.htm.
VIN decoders are available in www.lmctruck.com catalogues.
Old 11-29-2009, 12:35 AM   #6
79SWBchevy
ok well I snapped some pictures of my current motor mounts on the 250 I6 in my truck, they dont look anything like the ones in those links. what do you think?
Old 11-29-2009, 11:02 AM   #7
SSC's76
No No
SSC's76's Avatar
The wifes buick had a chevy 250 in it we stuffed in the 383 I had in my truck. Now just from measuring the engines mount points it looked like the mounts needed to go up to the next set of holes but they did not. If its a 250to v8 it will drop right in to the correct spot on your truck. If its not going in right somthing else may be casuing the issue. On the wifes car the engine sat cocked until the trans was in mounted may be a slight casting difference between I6 and v8 mounts that doesent like to sit well on the initial drop in on these swaps but in the end your should work.
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
