11-26-2009, 09:24 AM | #1 |
rear end gear replacment
how hard is it to replace the gears in a 12 bolts i wanna go 3.73 whats the process of replacing them??
11-26-2009, 09:43 AM | #2 |
Its a Truck Thing......
Re: rear end gear replacment
If you have never done it, I would advise this is not the area to do for fun.
If its an open carrier, its really not that hard IF you have all the special tools. But if you dont have a dial indicator to set the back lash, the orginal pinion shims to get the pinion depth close, (youll need a tool to set that), paste to check the ring gear pattern, inch pound torque wrench for the pinion pre-load check, and lots of patience, plus a press I wouldnt touch it...... Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
11-26-2009, 11:11 AM | #3 |
Still plays with trucks
3.73's in the truck 12-bolt are fairly common. You might be able to pick one up at the local pull it yourself junk yard for less than even the gear install kit costs. At mine it would cost me $85 for any truck / SUV rear axle assembly.
You can also just get the ring & pinion / carrier assembly if you have the tools to get it out for about $27 or hit the main yard and have them get you one off the shelf for $42 if they have one that old. With this the hardest part is setting the pinion preload when you are putting it back together. It really takes a dial indicator type inch-pound torque wrench to do it right. Not a common tool and not cheap. If you are not going to do this more than once you are better off financially to have a rear end shop replace the bearings and install the gears/carrier into your housing. You could always go with the 88-98 new body style rear axle assembly that pushes the tires out closer to what the front track width is on the square body trucks. That rear tire inset vs. the front bugs me on our trucks.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
11-26-2009, 10:45 AM | #4 |
^^^ What he said. You can very easily screw up a set of gears if you don't know what your doing. It is a much better idea to just find someone who does this on the side and pay them to do it.
11-26-2009, 01:27 PM | #5 |
Can you use a 90 91 suburban rear end. i thought they came with 3.73 or 3.42 with posi
2014 LTZ Z71 Silverado 82 C15 LQ4/4L80E Conversion 78 Suburban build (SOLD) 83 4x4 Suburban(SOLD) 82 C15 (my first truck) |
11-26-2009, 04:27 PM | #6 |
if you put a rear in from newer truck dont you have to do some moving and welding to get things to line up?
11-26-2009, 07:37 PM | #8 |
up here in MAINE there isnt any pull it yourself places thats what crappy about living in a salt belt LOL
11-26-2009, 08:23 PM | #9 |
that is one of the things i will never do on my truck i always let the pro do it because of the special tools you need.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 |
11-27-2009, 10:01 AM | #10 | |
http://67-72chevytrucks.com/vboard/s...t=fred&page=39 If you don't have the tools to do it then sticking with the truck 12-bolt is the best idea or maybe it is a good excuse to get a good 220-volt MIG welder and a cutting torch setup or plasma cutter.
11-27-2009, 09:42 AM | #11 |
My old 91 Suburban had 3.08's with the 4L60 trans and it wasn't posi.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars Last edited by 68 TT; 11-27-2009 at 10:01 AM. |
11-27-2009, 12:11 AM | #12 |
OutOfMyMind & I'llNeverKnowWhy
Not all that hard a job, just time consuming and requires a few specialized tools. You must have a inch pound dial torque wrench and a dial indicator. Impact wrench helpful too. I found the hardest part was getting the old pinion races out.
-Justin-Out of my mind and I'll never know why 1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed 1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6 1992 Pontiac Firebird T-Top 5.0L TBI 700R4 My cardomain page I don't like to save, it's more fun to spend!! |
