Front bumper 72
Any easy way to remove the 6 original bolts that hold the bumper on. I have sprayed them good with penetrating spray several times .I wish they would just break when I try to loosen them . The first one backed out good til the square part would not hold any more. Any help much appreciated , I will try again tomorrow if I have time.
Re: Front bumper 72
Tighten them back up and take a wire brush over the threads to clean the rust and junk off. A wire wheel on a air tool works the best.
If the bolt turns freely, you can try cutting a slot in the head of the bolt with a cut off wheel (on the outside). Then you can hold it from turning with a flat head screw driver or a flat tip pry bar.... Hope this helps.
1972 Chevy C10 SWB 1999 GMC Sonoma Mini 2008 Yamaha R1 2007 Harley Nightster |
Re: Front bumper 72
They break better when you tighten the snot out of them. I have loosened them by clamping a steel bar over the head to keep the square part in the slot but it was more trouble than it was worth.
Roadtrip!
![]() Join Date: Feb 2003
Re: Front bumper 72
If they are that bad, tighten them till they break...
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
Re: Front bumper 72
you can carefully grind the heads off with a small cutoff wheel too
Re: Front bumper 72
I'm sure he will have more luck but me, cutoff wheel and careful don't go together.
Re: Front bumper 72
Thanks everyone for the ideas ,I hope to try again in a little while.
![]() Join Date: Jul 2009
Re: Front bumper 72
Last weekend I removed the front bumper from my 67. I have very little experience working on these trucks, so take that into account. I ended up using my grinder with a flap disc (looks like layered sandpaper), to remove the bolt heads. Once I removed about 95% of the head, I hit the bolt with a punch to push it through. A little more grinding, and I was able to punch the bolts through. It took some time, but I did not damage the bumper, and it was a nice day to be outside working on the truck.
Craig |
70 Chevrolet=Obsession
Re: Front bumper 72
I just replaced both my front and rear bumpers and were they a PITA. I soaked the nuts with Liquid Wrench overnight, (the liquid not the spray) and got them off with a 3/4 socket and a 2ft. breaker bar. I pushed on the heads to keep them from turning.
![]() ![]() ![]() I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke! IT'S NOT EASY BEING GREEN! -Kermit the frog 1970 Chevrolet C-10 Longbed Stepside : 350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes) 1996 Toyota Corolla (Parts runner) |
Re: Front bumper 72
Got the bumper off , broke 3 off ,ground 1 off and the 2 others came off easy enough after much soaking. Thanks everyone .
Re: Front bumper 72
I just finished installing the front bumper after repainting it. It sure was easier going on than coming off. My budget is low so all Im doing is little things that dont cost anything using stuff I had on the shelf.
Re: Front bumper 72
Any pics of your accomplishment
70 SWB STEPSIDE 70 BLAZER 09 challenger |
Re: Front bumper 72
No pictures yet but will try soon.
