![]() Join Date: Nov 2009
HEI TDC help working on truck
I'm in the process of installing an HEI distributor on my 250. I haven't removed nor loosened the current original distributor so that I can identify TDC. the egine ran very well and started quickly. Well, the problem is that I'm able to position the rotor facing #1 cyclinder and the piston at TDC but the mark on the crank is 180 degrees off. If I install the new distributor how will I time it if the mark on the pulley doesn't hit where it supposed to. is it possible that someone install the pulley 180 off? Is there something I'm not seeing. Any help thanks
I am a Referee of life.
Re: HEI TDC help working on truck
The rotor may not face the # 1 plug at TDC.Only if it was installed that way will it point that way.When the dist is dropped in it may point any direction when the engine is #1 TDC.As long as that terminal ( where the rotor is pointed)on the cap is used as #1 it will work.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
#3 | |
69 Chevy 4x4 383 Power ![]() Last edited by haysonj; 11-29-2009 at 01:58 PM. |
I went ahead and set my distributor where the rotor faced #1 and i felt the piston @ TDC using a screw driver while ignoring the location of the mark on the crank. The engine starts and runs great but when I put the timing light, I see the mark 180 degrees (about 7pm). I used a piece of tape on the face of the crank pulley to see where the notch was as it was running. Now although it starts and runs good, I have no idea what the timing is as the notch is 180 off from the timing tab. Now, I can bring the notch on the crank to "0" (Manual tranmision) and #1 pistion to TDC but the rotor will not face #1 spark plug. Its more like facing the radiator cap. I can then turn that wire on the cap as #1. would that be okay? thanks for all your help. It runs good but I dont want to continue driving when I dont know actual timing. thanks again
You need to get the engine to TDC with the timing marks lined up. Now the rotor has to point at the dist cap tower that goes to the #1 spark plug. Make sure you keep the wires in the proper firing order. After doing this you can set your timing.
69 Chevy 4x4 383 Power ![]() |
I understand. I guess its more important to get the mark on the tab and #1 TDC then to worry if the rotor is pointing at #1 cylinder. Thanks for everyones help.
When I purchased the HEI, the manufactures instructions mentioned not to use the felt washer they supplied as it would not allow the HEI to ground properly thus voiding warrenty. I didn't install it and now I have a little oil seeping thru. I prefer to install it. what do you think. |
#7 | |
70 Chevrolet=Obsession
![]() ![]() ![]() I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke! IT'S NOT EASY BEING GREEN! -Kermit the frog 1970 Chevrolet C-10 Longbed Stepside : 350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes) 1996 Toyota Corolla (Parts runner) |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
I always install the dizzy gasket...
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
You will want to use the gasket for the dizzy. It may not make much difference on an older vehicle but the worm gears on the dizzy and the cam will be tighter than what they're meant to be as you're actually lowering the dizzy about 1/16 of an inch which amount's to .060.
Re: 250 TDC
After taking everybodies advice into consideration, I removed distibutor completely and focused on aligning the notch on the crank pulley to the timing tab on the block at 0 degrees (MT) at the same time as having #1 at TDC. NOT possible. Every time I got #1 to TDC, the mark was 180 degrees off (at 7pm). Do you think my truck has the wrong pulley that would have the notch in the wrong place? Since the pulley can only be positioned on the crank one way, Is it possible that the pulley has both a TDC and a BTDC marking and I just can't find the TDC mark? The truck is running great but its bugging me not knowing why I have this situation. Thanks for everyones help.
Re: 250 TDC
yeah at 180 off, the piston would be at BDC (bottom dead center)... This would have nothing to do with the camshaft. Suggest getting a new harmonic balancer. (the mark is on the balancer, not the pulley)
The following story may or may not be related, but it's worth telling: The harmonic balancer weight is pressed on with a rubber gasket in the middle, so it can vibrate. I had an 88 Jeep Cherokee where it had actually moved a bunch and was off about 70 degrees and it started creeping back into the timing cover... I didn't realise it had creeped back towards the engine until it started squeaking and I ended up having oil flung all over my engine bay... that repair sucked. Needless to say, i went to Chevy after that... ![]()
1970 C20 LWB Fleetside with a 472 Caddy engine! TH400 Restoration in progress 07 Yamaha 650 V-Star Custom 83 Honda V-45 Magna Last edited by PowerPro; 12-01-2009 at 11:55 AM. |
#12 | |
Re: 250 TDC
69 Chevy 4x4 383 Power ![]() Last edited by haysonj; 12-01-2009 at 09:59 PM. |
After thinking about this a little more i think you may have the wrong dampener or it has slipped really bad I have never seen one slip 180 degrees. You might try looking to see if there's more than one key slot in the dampener. My after market dampener has three different key slots
thanks haysonj. I'm also thinking the balancer has slipped. The truck is currently running good. I did find #1TDC and dropped the distributor in properly. And it starts from cold on the second-third crank but when using a timing light its at 7pm. I would like to know where the standard location of the notch is in relation to the key slot on the balancer. That way I can compare and see if mine has shifted over the years. I looked for new balancers on the net but could not find a pic showing the notch and the slot.
#15 |
It is not he harmonic balancer!. Like others have already written, there are two "TDS". One will be correct relative to the timing mark and one will be 180 degrees off. Follow directions by haysonj.
#16 | |
Since he's stated that the piston is TDC with the balancer 180 off then the only solution is that the balancer is either spun or not the correct balancer assuming it doesnt' have an adjustable keyway. (although I've never seen one that would adjust 180 degrees) Last edited by highperf4x4; 12-04-2009 at 11:49 AM. |
#17 |
I called Damper doctor yesterday and they specified that when you position the key way at 12noon, the notch on the balancer should be 45 degrees to the right (2pm). I checked my balancer last night and found that the notch is at 8pm not 2pm. I still need to confirm if the balancer seperated or if its even the correct one. Regardless, at least now I know why. Napa had the balancer for $79. Next question is how to replace it. My crank is not drilled in the center so I can't use the tool to install it. I hate to beat it in. I was reading how some have drilled and tapped, which to me sounds like the more correct way of
![]() thanks for all the great help and ideas. |
#18 | |
#19 |
Thanks makes sense. I guess I should actually install the bolt and washer after the install.
#20 |
#21 |
Being that I'll be doing the switch out soon. Is there anything else I could should replace while the balancer is off? crank seal, timing chain, cover gasket, water pump etc. All is goo know but I'm trying to look ahead.
#22 |
I would definitely replace the seal. I don't know that I would worry about the rest.
