11-30-2009, 09:50 PM | #1 |
Shoulder Seat Belts in a 5 Window?
Anybody know if its do-able to mount the bolts/plates for shoulder strap seatbelts in a '51 5 window to the frame near where the door closes with the cab?
Has anybody had any success with this? Thanks |
11-30-2009, 10:19 PM | #2 |
Re: Shoulder Seat Belts in a 5 Window?
11-30-2009, 10:40 PM | #3 |
I considered this when I installed my 3-Point Autoloc set but I found that the door frame position was too far forward to be comfortable across the chest. I took a 3" x 4" piece of steel and, with a contour gauge, shaped it to the contour of the metal corner. I welded it by spot welding in 2 places as seen in the link to the Juliano's installation instructions.
11-30-2009, 10:55 PM | #4 |
These are a good start. Thanks
12-01-2009, 12:45 AM | #5 |
not for a 5 window...
12-01-2009, 01:12 PM | #6 |
Hey Mr.Tucker, did you view the link to the seat belt installation on a 5-Window AD?
12-08-2009, 01:56 PM | #7 | |
I'm probably wrong, but it just doesn't sit well with me... |
12-08-2009, 04:38 PM | #8 |
I too am running Julianos 3 point. The kit is very well put together with very little welding. I did add a 1/2" (about 9" square) plate under the truck where the seatbelt bolts down through the cab floor. I did the plates at the seat mounts and then welded it together with 1" solid sqare tube. I don't expect to walk away from a high speed front end crash. It just might keep the seats and belts from ripping through the cab floor.
My build, 53 GMC / S10 swap http://67-72chevytrucks.com/vboard/s...d.php?t=305723 My build, 59 Chevy / 88 fullsize swap http://67-72chevytrucks.com/vboard/s...hlight=sgtusmc U.S. Marines - Certified Counselors to the 72 Virgins Dating Club. |
12-08-2009, 04:59 PM | #9 | |
Thanks!
'51 Chevrolet 3100 |
12-07-2009, 11:07 PM | #10 |
How many hours would you all estimate an experienced welder and custom car installer would take to install two of these shoulder harness seatbelts (link below) in my 5-window 51? Thanks
http://www.julianos.com/how2_3point_...evy_truck.html
12-07-2009, 11:39 PM | #11 |
I had mine installed in about 3 hours including bending the metal and beer! I cleaned up the weld later.
A professional should be able to do it in that time or less, say 2 hours if you had the metal bent already. Last edited by Atomsplitter; 12-07-2009 at 11:41 PM. |
12-07-2009, 11:48 PM | #12 |
Thats awesome. So if i were to estimate the value of 3 hours of install time by an experienced custom installer/welder... what do you think I should offer for the install? I know its hard to say, and I wouldnt hold anybody to a number, i just have no idea what that would be worth. He would use all his tools at his garage. (I would pay him in cash, not just beer... but that would be involved). Thanks
'51 Chevrolet 3100 Last edited by chevyky; 12-07-2009 at 11:49 PM. |
12-08-2009, 08:00 AM | #13 | |
1971 Corvette convertible 454@ 525 hp 1936 Chevy Truck street rod 1952 Chevy truck hot rod build http://www.killbillet.com/showthread...2-Chevy-Cut-up 1964 F 100 custom street rod http://www.ford-trucks.com/forums/12...mark-viii.html 1950 custom Chevy Truck |
12-08-2009, 10:05 AM | #14 |
I think we are only state (GA) left where you are not required to wear a seatbelt in a truck. Which now after seeing this post makes me remember we will be traveling to Pigeon Forge next year, so I guess I better be figuring out what seat belts to use myself.
12-08-2009, 12:20 PM | #15 |
Assuming the seat(s), carpet and headliner are pulled and everything is ready to drill and weld. Do those retractors have inertia locks?
12-08-2009, 01:43 PM | #16 |
i did mime in a day and no welding. surprisingly simple and worth every penny i used julinos airplane buckles. one thing to keep in mind the passenger seat is the most dangerous. apparently the glove box can open and do some real damage to your passenger during an impact. i've always believed; spend good money on safety and save money elsewhere...
GT
Greg 1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school http://67-72chevytrucks.com/vboard/s...=215079&page=5 Last edited by mylow53; 12-08-2009 at 01:47 PM. |
12-08-2009, 05:21 PM | #17 | |
12-08-2009, 01:51 PM | #18 |
here's a pict of my mounting point
GT
Greg 1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school http://67-72chevytrucks.com/vboard/s...=215079&page=5 |
12-08-2009, 06:12 PM | #19 |
the belts are cool looking but maybe I'm used to my 03 dodge. there a 2 hand buckle. but hey they hold.
and yes i would expect to have a closed casket funeral if i were to really hit something at speed. forget the belts my head has no air bag to hit just some billet aluminum... this ain't no volvo. hey it beats dieing slowly in a hospital my 2 cents GT
12-08-2009, 11:22 PM | #20 |
I guess we all have the same reservations about the strength of the mounts but as they say it's better than nothing. I also have reservations about my hood latch and the door latches, eventually I'll replace all the latches with modern style bear claws.
These trucks were NOT designed to take us safely down the road at modern speeds. |
12-08-2009, 11:42 PM | #21 | |
03-17-2016, 07:54 AM | #22 |
Has anyone done any further development of seat belts in these old trucks? Approaching time to install belts in my '59 and, before I saw this, I was trying to devise a way to handle the load imposed by the top belt mounting point. The '59 appears to have even less structure than the 5 Window. If I get in a wreck, I don't want to take the back and top of the cab with me as I move forward. I was thinking about a tall narrow triangular structure that was mounted to the floor (and additional floor plate or frame) and the top of the cab much like the mounting shown in the attached link for the Julianos belt setup. Any proven ideas? Thanks...dug
My Build - http://67-72chevytrucks.com/vboard/s...d.php?t=515876 |
