11-30-2009, 09:52 PM | #1 |
Suggestions on flip kit.
Only looking for a couple more inches of rear drop, was thinking of rear hangers to go with my 2" drop shackles. After looking a prices, am i better to remove the shackles and install a flip kit? Any suggestions on who makes the best flip kit. Thanks
12-01-2009, 01:44 AM | #2 |
Re: Suggestions on flip kit.
Yes, I would do a flip kit over shackle, hanger, & removed leafs. Bell Tech & Western Chassis both make quality flip kits.
12-01-2009, 12:16 PM | #3 |
x2 I would NOT get a DJM flip kit
12-01-2009, 12:59 PM | #4 |
Formerly- 1972SuperCheyenne
Mine is Western Chassis, worked great.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
12-01-2009, 07:58 PM | #6 |
67-72 parts collector,…
I think there are better quality flip kits on the market. I feel like Western Chassis and Belltech are superior choices.
I think DJM makes a decent drop spindle,... but their Flip Kit c-notches and axle saddles are a cheaper design than the WC or Belltech version.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 12-01-2009 at 08:01 PM. |
12-01-2009, 01:16 PM | #7 |
yeller
WC kits installed here, 2 of them...was happy with both.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
12-01-2009, 02:01 PM | #8 |
Slots go on anything!
What does the WC run $ wise? Anything else besides shock relocators needed?
12-01-2009, 02:09 PM | #9 |
I got mine thru SportTruck Direct for about $150 as a kit w/c-sections, flip brackets, & shock extensions. Others have mentioned STD has had issues similar to CPP as far as CS goes so maybe check & see other possibilities before committing.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 12-01-2009 at 02:10 PM. |
12-01-2009, 02:13 PM | #10 |
I have kind of been on the lookout. I am leaning for a 4/6 or 5/6 drop. I have a line on some spindles, and was going to cut the stock spring in the front. It will be a start.
12-01-2009, 02:14 PM | #11 |
Should work fine.
12-01-2009, 07:01 PM | #12 |
Northern the picture you saw of my truck where with the drop spindles and the rear flip kit. I had the western chassis flip kit along with the western chassis spindles.
If you don't use the truck to haul much stuff you could remove the overload spring. I did that in mine recently.
83 C10 Stepside (SOLD, it was a blast!) 383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt S475 and C4 DM running, fine tuning turbo= Douchebag Racing: Runs Fine all the Time |
12-01-2009, 08:04 PM | #13 |
6.0 powered square
I have a beltec on mine haven't had any problems with it
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
12-01-2009, 09:14 PM | #14 |
mgcuaghys flip kit went in perfectly
