Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 12-01-2009, 09:27 PM   #1
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Need a stock Roof height for a 4x4 P/U
since winter is coming I have been thinking about a 4x4 project and have a line on a 67.....
one small problem is my garage door is only 7 feet tall (can you see where I'm going with this) my f 350 with the cap on is a squeeze for the door...
so I need to figure out what the stock height is and then figure how much total lift ( tires/body and springs) I can put into it ...Then find the best way to get it to 6 feet 11 inches...
Hottrucks is offline   Reply With Quote
Old 12-07-2009, 12:30 AM   #2
Big-Blue
Big-Blue's Avatar
Re: Need a stock Roof height for a 4x4 P/U
I already have the lift on mine so I am no help.
However, you could always go with a low profile tire until you are near completion...just don't plan on parking in the garage once it's done??
Big-Blue is offline   Reply With Quote
Old 12-07-2009, 12:39 AM   #3
msgross
msgross's Avatar
I can check when I get home... I'm think 4" w/33's will easily work... maybe 6" with 35's but that would be close I bet...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 12-07-2009, 12:47 AM   #4
CG
BlahBlahBlah
My 71 K20 has no lift with 33 inch tires and fits in a 7ft garage door with about 4 inches to spare. Its dark outside and no outside light where my truck is sitting so I cant get exact.
Old 12-07-2009, 06:55 AM   #5
Hottrucks
Hottrucks's Avatar
thanx Guy looking forward to it...by te sounds of it a set of 35's is the correct size///thats about as much as I wanted to go which work perfect it seem like any bigger and the side walls turn to sponge
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Old 12-07-2009, 12:18 PM   #6
tallhoedude
ROCKWELL 5 TON CLUB !!
tallhoedude's Avatar
Rachet strap the suspension tight,and drag it out on the rotors!!
you should be able to clear a 12" lift that way(been there,lol)
as far as stock roof height,sorry cant help ya there
1970 K5 "ON THE ROCKS" PROJECT:500hp 6.0 fuel injected. 2wd sm465 trans,t136 2.5 ton transfercase,5ton rockwells with 9.34 gears,custom wheel disc brakes,full hydro steering20+" OF LIFT AND 67/35/25's..67" tall TRACTOR TIRES.."THE MUD SLUT!!"
MY BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=221935
1997 TAHOE,SAS D60 14B,5:13 DISC BRAKES,CROSSOVER STEER,HYDRO ASSIST,42 IROKS
HINT:NEW NAME "K5ontheROCKS!"
tallhoedude is offline   Reply With Quote
Old 12-07-2009, 03:49 PM   #7
Hottrucks
Hottrucks's Avatar
ummmm sorry never had that problem but I have had them so low that they wouldn't make the transition from garage floor to the driveway......ooops!!
ok next question does 35's and a 4" lift work or am I looking at rubbing issues..I just dont want the hassle from the PoPo if I don't have too...
Old 12-07-2009, 04:15 PM   #8
sdailey
The Few, The Proud
sdailey's Avatar
You shouldn't have any issues running 35's with a 4' lift.
What did you figure out about it fitting in your garage?
Here's my '69 running 33's and a 4" lift. My cab isn't mounted yet, but looking at the picture I don't think mine will fit with the lift that I have. By the way my garage door openings are 6'-10".
Shannon
sdailey is offline   Reply With Quote
Old 12-07-2009, 07:17 PM   #9
msgross
msgross's Avatar
just let the air out of the tires shannon,,, or better yet, build your pole barn because of the new truck! i'm sure your wife will understand!
The Garage:
Old 12-07-2009, 08:05 PM   #10
sdailey
The Few, The Proud
sdailey's Avatar
Mike,
I'm way ahead of you. I found a set of steel wheels to help with my height dilemma for the time being. The garage is on hold for the time being.
Shannon
