Old 12-02-2009, 10:27 PM   #1
6772fan
Active Member
6772fan's Avatar
Standard guage to tach swap-78 chevy
I bought a tach gauge cluster from BigJake on the board. It's from a 79 Blazer. The truck that it is going into is a 78 Chevy with standard gauges with electrical oil pressure switch.
Question- Is this a direct plug and play or does it require wiring modifications at the connector under the dash? The tach cluster comes with the tach wiring harness. Thanks.
Lane
1979 Chevy SWB- (Second owner- Father in Law was first)
1979 Chevy Silverado SWB-Red/Red
6772fan is offline   Reply With Quote
Old 12-02-2009, 10:52 PM   #2
Jonboy
Slots go on anything!
Re: Standard guage to tach swap-78 chevy
The tach wiring harness is seperate from teh cluster harness. It will have 3 wires (IIRC), and plug in to the tach only. You may have to repin the cluster wiring. If you can get the pigtail from the donor, it will make everything a lot easier. The colors will be the same, but may be in different locations. You will probably have to swap temp and oil senders as well.
Jonboy is offline   Reply With Quote
Old 12-02-2009, 11:02 PM   #3
ghettoluxury
ghettoluxury's Avatar
trace the circit board on both clusters and see if they are the same if so you are good 2 go if not re-pin to match
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
