Old 12-06-2009, 09:20 PM   #1
harrdawg54
harrdawg54's Avatar
Help Adjusting Door
I just finished painting my truck and am trying to adjust the doors. I had no issues with the drivers side but when I tried to do the passengers side I adjusted the door to the opening then installed the striker on the cab....and the door stuck shut. I had to use a dremel to cut slots in the back of the bolts to be able to unscrew them to finally beat the door open. I changed out the striker because I didn't have this problem before I painted and now have the same problem. My question is why is it sticking and how do I fix it. Any help is appreciated.
1969 Chevy K20 Custom Camper
350, 4sp, 33's
High on plans, Low on funds
harrdawg54 is offline   Reply With Quote
Old 12-07-2009, 01:21 AM   #2
dan42
dan42's Avatar
Re: Help Adjusting Door
You didn't have this problem before and now you have the same problem? Huh? Do you mean, before you painted the truck you had the problem with the door, or you didn't and now you do? Did you take the door off to paint it? Need more info.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 12-07-2009, 02:13 AM   #3
harrdawg54
harrdawg54's Avatar
Sorry for the confusion, I did not have this problem before painting. I did remove the doors to paint them and like I said no problems with the drivers side but the passenger side is fighting me all the way.
350, 4sp, 33's
Old 12-07-2009, 10:54 AM   #4
dan42
dan42's Avatar
It sounds as if the door is just out of alignment, and can be adjusted fairly easily. Did you mark around where the hinges were before so that you could put them in the same place? Since you painted it, they way to dod it would be with an awl and scratch a line around the hinge. The striker plate is also adjustable, in and out.
Philippians 4: 6-7
Old 12-07-2009, 12:57 PM   #5
cedorris
1972 Chevy Cheyenne Super
cedorris's Avatar
I'm worried I'm going to have this same problem... Except there is no way to mark it since I'm doing a cab swap.
Any suggestions?
-Clayton
1972 Cheyenne Super LWB 350 - farm truck restore project - twitter @oldgreen
cedorris is offline   Reply With Quote
Old 12-07-2009, 11:06 PM   #6
redbaron69
redbaron69's Avatar
a trick i have used before is to take a small drill like a 1/8 or 3/16 and drill a few holes through the hinge and body.(at oppisite corners) then when you put the door back up after paint you can take a roll pin, steel dowl...etc and line the holes back up. this will get you real real close.
69 short fleet 350/350 "under construction"
70 short step 307/3 speed
redbaron69 is offline   Reply With Quote
