Old 12-09-2009, 05:19 AM   #1
bluex
bluex's Avatar
Truck arm rear suspension
Anyone put a 67-72 rear suspension in a 73-87?
I ran across a conversion kit on CPP's site, but not pics or info, just a $1200 price.
Here is one from hotrods to hell...
http://www.hotrodstohell.net/in_the_works/hillbilly.htm
Looks like there kits run around $2000
bluex is offline   Reply With Quote
Old 12-09-2009, 10:04 AM   #2
68 TT
Still plays with trucks
68 TT's Avatar
Re: Truck arm rear suspension
Wouldn't be that hard since they share the same frame rail spacing. Just find an old truck arm donor and either transfer over all the parts or do a back half frame swap similar to what people do to make a long bed into a short bed.
If you did it right you could put the leaf spring stuff back on the donor rig and sell it off to recover some or all of your investment.
I see them as truck bed trailers every now and then for $150 to $300.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 12-09-2009, 12:54 PM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
There was a thread going in the suspension section on this topic. Do a search there and see if it pulls up. If not I will try to locate it later.....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-09-2009, 03:30 PM   #4
Damien
Damien's Avatar
here ya go. I've been watching this for future reference.
http://67-72chevytrucks.com/vboard/s...d.php?t=364043
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
Old 12-10-2009, 12:12 AM   #5
2tons of fun
do it,
pick up a scrap $200 truck and scalp all the rear stuff of it.
63-72
2tons of fun is offline   Reply With Quote
Old 12-10-2009, 02:31 AM   #6
bluex
bluex's Avatar
Thanks guys, thats a great thread with lots of good info. I couldnt find it b/c I was searching for truck arms and not trailing arms.
Now I've got something else to add to the list of things to do. Check the other thread for the article on the CPP kit. It dosent seem like a bad price for everything it includes.
68 TT, that was exactly what I was thinking.....
now to find a cheap truck.....
Any difference in arm length between long and short bed??
Old 12-11-2009, 12:03 PM   #7
joe231
joe231's Avatar
nope, they are the same length
I have been thinking about doing this conversion for some time. We have a '66 with coils in the rear, and I really like how it rides and handles. I think I can even get all the stuff for free. My wife's uncle has several 64-66's sitting in his field
pretty sure the trailing arm cross member will need to be modified to fit the newer frame, shouldn't be bad though.....
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 12-11-2009, 12:22 PM   #8
68 TT
68 TT's Avatar
That is good to know. I plan on turning my long bed C-10 into a short bed. Glad to know I don't need to mess with the truck arm stuff too.
Old 12-11-2009, 01:46 PM   #9
westofb
I really hate wet sanding!
westofb's Avatar
3/4 tons are the same too, but the trailing arms are re-enforced to make them stronger.
Jeff,
68 C-10
75 C-20, now a C-10!
10 F-150
westofb is offline   Reply With Quote
Old 12-11-2009, 01:56 PM   #10
68 TT
68 TT's Avatar
How are they reinforced? Any pics of the two for comparison?
Old 12-11-2009, 03:51 AM   #11
bluex
bluex's Avatar
http://www.classicperform.com/Videos/Videos.htm
Look at the bottom screen on the lower left. The video is titled '79 C-10 Truck. Pretty nice.
I'm planning a call to CPP tomorrow, I'll see if I can get anymore info on the truck. I'd like to know how much drop the springs on it are. I know those modular spindles are 2". According to the article they used a 3" spring in back, but the video dosent say what spring was used up front. Love that stance on this truck and it corners so flat....
Install article on the kit:
http://www.classicperform.com/tech_a...iling_Arms.htm
Old 12-11-2009, 05:46 AM   #12
andrewmp6
For 2 grand you can get a bolt on air bag 4 link from ride tech.
Old 12-11-2009, 09:56 AM   #13
bluex
bluex's Avatar
Ya, but then I'd need an air management system, and I'd want to do the front too and im in it for 4-5k by the time its all done.
I'm thinking with a used set of arms, new bushings and some powdercoat on those and the CPP kit (-arms is 609) and could bring the trailing arm setup in for under a grand and be done....
Old 12-11-2009, 06:16 PM   #14
bluex
bluex's Avatar
Just got off the phone with CPP.
Kit is designed for 63-72 arms and will work with a stock set of arms.
The truck in that video uses their modular brake kit with a 2" drop spindle
They also used a 2" drop spring up front for 4" total.
Their rear arms have no drop built into them
and the truck has 3" 63-72 drop coils in the rear, or can use any other drop or stock spring for those years.
I'm thinking you will get another 2-3" drop out of the swap due to the axle being located on the top of the arms, so this truck would have a 4/6 or so drop from stock.
Now I just need some arms and 6 bills.....
Old 12-11-2009, 07:10 PM   #15
Conundrum
Conundrum's Avatar
I'm pretty sure I seen a magazine tech article where they were installing the cpp kit on a mid-late 70s short bed. I believe it was classic trucks, probably 3 years ago, I would try and find it but i'm pretty sure it got left behind when I moved back from Michigan.
74 GMC SWB Project "Sin-thia" Static Dropped 8"f/10"r
http://67-72chevytrucks.com/vboard/s...d.php?t=460030
97 GMC reg cab short bed, 4.3V6 / 5spd, daily driver
220,000 miles, all stock for now
Conundrum is offline   Reply With Quote
Old 12-12-2009, 01:18 AM   #16
2tons of fun
the 3/4 tons are clad with a additional 1/8" plate on the top and bottom.
i will have a set of half tons that i dont need, hit me up if you want to work out how to ship them.
Old 12-12-2009, 11:11 AM   #17
68 TT
68 TT's Avatar
I already have the 1/2 ton truck arm stuff in my C-10. I can just reinforce the arms with some 1/8 flat stock like I do with car trailing arms then to beef them up. No big deal.
My 67 body will be going onto the 78 K20 chassis and the 78 body will be going onto the 67 C-10 truck arm chassis. Both are long beds but the 78 will become a short bed eventually. The wheel base of the 78 body is a little longer than the 67 so a little frame modification will be needed on both rigs.
Old 12-12-2009, 02:22 AM   #18
bluex
bluex's Avatar
It is linked in this thread on post #7.
Also linked in the thread in post #4 in the suspension forum.
Old 12-11-2009, 02:36 PM   #19
softballnrd27
Always a work in progress
softballnrd27's Avatar
I plan on doing the same thing as well to my 85. There are quite a few trucks in the pull a part yard that I can pick from so I will go that route and hopefully keep the cost under $300
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 12-11-2009, 02:46 PM   #20
78-5.3
78-5.3's Avatar
what advantage is going older truck coil and trailing arm!????
78-5.3 is offline   Reply With Quote
Old 12-11-2009, 03:55 PM   #21
joe231
joe231's Avatar
if your yard is anything like ours here, if you buy a piece at a time you will probably get it quite a bit cheaper
the ride is way smoother, traction is better, and the cornering and handling are better also. You can adapt bags or coil overs rather easily also. Makes for a nice corner carver....
I believe there are guys running 9's and 10's in the quarter mile with the stock arms.
CHEVY ONLY
Old 12-11-2009, 05:54 PM   #22
softballnrd27
That is the whole reason for me. I have seen some fast trucks launch really hard with that suspension set-up. I can get a good suspension for next to nothing and be able to go from strip to street duties rather easily.
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 12-12-2009, 10:25 PM   #23
KQQL IT
At the body shop.
KQQL IT's Avatar
leaf springs and cal trac bars have done 8's on 10.5 tires on a hoosier drag radial
Old 12-13-2009, 12:56 PM   #24
68 TT
68 TT's Avatar
I have Cal-Trac's on my Camaro and have run them on several other cars. They work fantastic for drag racing on a leaf spring vehicle but just aren't meant for the street if you want to go fast around corners. The Camaro gets terrible oversteer if I hit a bump going around a corner.
They don't let the rear end articulate like it needs to so the vehicle has good street manners. Most guys who run them on the street and track back off the link bar so they have a pretty good gap at the front pivot bolt when they take the car on the street. This diminishes their straight line capabilities quite a bit. It only takes a minute to make the change but for something like CPP's truck doing auto-x the Cal-Trac bar just won't behave well. Truck arm is far superior here.
Old 12-13-2009, 04:07 PM   #25
Pyrotechnic
Pyrotechnic's Avatar
What are the options for exhaust with the truck arms ? My mufflers are just ahead of the rear axle, seems they would be in the way of the arms ? Never seen the exhaust on a stock 67-72 but imagine the mufflers have to be ahead of the trailing arm crossmember ?
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
