Old 12-09-2009, 07:05 PM   #1
BAGNDRAGIT
Just Not Low Enough!
BAGNDRAGIT's Avatar
Question Header Question
ok guys, i have searched with no luck, and i have seen it, so i know im not crazy haha. i am looking for a set of headers that will clear the factory clutch linkage on a 67 2wd w/ a 327, and they have to be above the framerails., hence why i am changing them. they drag on the ground.
Thanks in advance!!
NEED ELECTRICAL HELP? ASK ME!
67-72 Full Wiring Diagrams
Lots Of Info, TAKE A LOOK
1967 Chevy C-10 Shortbox Bagged 327 4spd
Previous:
1971 Chevy C-10 Short Sep I6 Auto (Traded)
1973 Chevy C-20 *THE REDNECK BATTLE TRUCK*
2001 Chevy Silverado 2Dr 5.3L Shortbox. R.I.P.
1969 Volkswagen Bug
This is my first meeting, I have a horsepower problem.
BAGNDRAGIT is offline   Reply With Quote
Old 12-09-2009, 07:55 PM   #2
69GMCLonghorn
69GMCLonghorn's Avatar
Re: Header Question
It's going to have to be shorty headers from what I know. All the long tube headers I've seen run below the frame rails. I guess that's an advantage to not lowering my truck. They could've hung down a foot with no worries. Good luck! I'm sure if they're out there someone will know what to use.
69GMCLonghorn is offline   Reply With Quote
Old 12-09-2009, 10:07 PM   #3
unclewatts
70 Chevrolet=Obsession
unclewatts's Avatar
Re: Header Question
When I bought my Headman headers, the guy asked to see my clutch linkage. He told me that the clutch linkage was located in 2 different locations on our trucks. Hedman makes 2 different header models depending on the location of the crosshaft and they're both long pipe headers. When I had them installed they fit perfectly.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke!
IT'S NOT EASY BEING GREEN! -Kermit the frog
1970 Chevrolet C-10 Longbed Stepside :
350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes)
1996 Toyota Corolla (Parts runner)
unclewatts is offline   Reply With Quote
Old 12-10-2009, 02:04 PM   #4
BAGNDRAGIT
BAGNDRAGIT's Avatar
Re: Header Question
ok so i would need to call headman to see what type i have, unless you know the difference?
and the longtubes you have hang below the frame correct.
i thought sanderson made a pair that would fit around the linkage, and were shorty.
BTW Thanks unclewatts and 69GMCLonghorn
Previous:
1969 Volkswagen Bug
Old 12-10-2009, 02:14 PM   #5
marcsRX
68 C10 SWB
marcsRX's Avatar
Re: Header Question
I ordered these after getting a set of long tubes from Summit. I had the same issue as you...
Early Classic is proud to offer the highest quality, American-made Small Block Headers available for 1967-'72 GM small block trucks. These new mid-length headers are swept rearward and dump below the firewall eliminating ground clearance problems for lowered trucks.
These 16 gauge, mandrel bent beauties come with the only patented leak-free flange on the market. As an added bonus, a ceramic thermal barrier coating has been applied inside and out for years of trouble-free performance. (Pair)
"How much physical pain do you go through on a daily basis that you can directly attribute to your lack of intelligence?" -R0bman
marcsRX is offline   Reply With Quote
Old 12-10-2009, 02:49 PM   #6
BAGNDRAGIT
BAGNDRAGIT's Avatar
Re: Header Question
Thank you so much marcsRX
i was racking my brain trying to track them down.
much appreciated.
Previous:
1969 Volkswagen Bug
Old 12-10-2009, 02:56 PM   #7
marcsRX
68 C10 SWB
marcsRX's Avatar
Re: Header Question
That's why this is called a "community".
Post pics when its all buttoned up!
Old 02-02-2010, 11:48 AM   #8
snaus32
snaus32's Avatar
Re: Header Question
is there a part numbers for those? I couldn't find them.
snaus32 is offline   Reply With Quote
Old 12-10-2009, 11:05 PM   #9
unclewatts
unclewatts's Avatar
Re: Header Question
Yes, they hang down well below the frame. P.S. Your very welcome.
Old 12-11-2009, 01:11 AM   #10
ace of shades
NEWBIE!!
ace of shades's Avatar
Re: Header Question
I'm not too sure about the mouse motors; but I know that when I swapped over to my elephant I'm running a set of chevell shortie headers. They dump out pointing towards the ground but with a simple cut, weld, drive you have it made
Water is for the weak
I don't like cocaine.. I just like the smell of it
"Well there might be a dime up a goats ass too, but I ain't looken" - Grandpa
VolksRods
ace of shades is offline   Reply With Quote
Old 01-31-2010, 10:12 PM   #11
zammer
Addicted user
zammer's Avatar
Re: Header Question
Hello,
I just bought a set of the sanderson headers from Early Classic Ent, and I am having troubles clearing my clutch link on my 4 speed trans. Anyone else come across this issue?
Does anyone have pics of the drivers side sanderson header installed with a 4 speed trans in a 67-72 c10?
I have a 71 2wd blazer... any help would be great
thanks!
zammer is offline   Reply With Quote
Old 02-01-2010, 08:19 AM   #12
dznucks
dznucks's Avatar
Re: Header Question
I just installed these edelbrocks on a '69 with a stock clutch linkage.
i found the best price on the ceramic coated ones at ajusa.com
dznucks is offline   Reply With Quote
Old 02-01-2010, 10:04 AM   #13
zammer
Addicted user
zammer's Avatar
Re: Header Question
do those headers clear the frame so you can use them on a lowered truck?
Old 02-01-2010, 03:16 PM   #14
dznucks
dznucks's Avatar
Re: Header Question
zammer, if your asking about the edelbrock hotrod headers. yes they will clear the frame with plenty of room.
here is the post with pics. you can get an idea of how close they come to the frame. my truck is lowered 3" in the front (soon to be bagged) and the back is bagged. The header flanges do not sit any lower than the lowest part of your frame.
http://67-72chevytrucks.com/vboard/s...d.php?t=380456
Old 02-01-2010, 07:25 PM   #15
MTtruck
MTtruck's Avatar
Re: Header Question
I used a set of pretty long headers on my 68 4x4 and had to do some fairly simple mods to my linkage. not to bad if you know how to weld. ill post a pic of my modification soon.
Paul"Give old trucks a second chance"
MTtruck is offline   Reply With Quote
