12-10-2009, 07:33 PM | #1 |
Simple? What's simple?
Radiator hoses?
My 69 has what appears to be poor replacements for the factory radiator hoses.
On top, (hard steel tubing): and on the bottom (no pictures) it has a standard rubber hose, which is held in place with aluminum sheet metal that is actually touching the alternator belt.\ What is supposed to be going on here?
CURRENT '50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build '63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos '66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos '69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!) '72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh '99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily) '99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs) SOLD '71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder) |
12-10-2009, 07:38 PM | #2 |
Re: Radiator hoses?
You should just have 2 rubber hoses with hose clamps on them, just like the other 8 billion vehicles on the road. The top pipe might now be hurting anything, but it's kind of goofy. I would just buy a couple new hoses and ace the Mickey Mouse action.
12-10-2009, 07:56 PM | #3 |
member #16
Re: Radiator hoses?
The 4x4 trucks have a metal tube on the upper hose. see pic in link. Yours looks like it has an extra tube.
http://67-72chevytrucks.com/vboard/s...d.php?t=108105
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
12-10-2009, 09:50 PM | #4 | |
Re: Radiator hoses?
As for the bottom, it looks like an original molded hose; the alternator brackets are non original, is the hose close enough to the belt that moving the alternator outward could cause contact between them?
12-10-2009, 09:58 PM | #5 |
Re: Radiator hoses?
As said earlier, the metal hose is a stock unit for 4x4 trucks, but there has been some unique engineering going on for the alternator bracket. It should be on the driver's side in the original configuration, but on the positive side it looks like you still have the original top alternator bracket. What is the stuff mounted to the drivers side of the engine?
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
12-10-2009, 10:14 PM | #6 | |
Re: Radiator hoses?
I have all the original stuff that was pulled off the motor, so I could shift the alternator back over. That said, the truck appears to have a short water pump on it. Is that original, or should it have a long pump? The reason I ask is that I was thinking of getting my hands on a set of later model serpentine brackets for the PS and alternator (cheap at the local boneyard) to make this stuff work better for the moment until I can figure it out for good.
12-10-2009, 10:46 PM | #7 |
Re: Radiator hoses?
The bracket on the left side looks like it originally went to a rig that had a left side ac compresser.
All I'm going to say is that setup is wrong for your truck. Did the P/O swap engines by chance and use the brackets off the engine that he put in and not swap the original brackets over? The hoses just look sad and I would install good quality new hoses no matter what else I did. I have the alternator mounted on the passenger side on my truck because I have a 350 out of a 79 Elkie in it with a long water pump. Also the simple fact that I broke off one of the bolts in the left head contributed to the swap. the good thing is that it makes the stock power steering pump easier to get to. Last edited by mr48chev; 12-10-2009 at 10:49 PM. |
12-11-2009, 08:39 AM | #8 | |
Re: Radiator hoses?
I am planning to replace the hoses; she needs a new radiator (this one is the original!) as well. I am debating whether I want to return the accesories to stock or go with a passenger's side alternator / serpentine setup, just for the convenience of it (and the ready availability of parts to make the swap)
CURRENT '50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build '63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos '66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos '69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!) '72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh '99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily) '99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs) SOLD '71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder) Last edited by JJorgensen52; 12-11-2009 at 10:36 AM. |
