12-12-2009, 08:38 PM | #1 |
The oddest Todd around
Steering wheel alignment
Ok... so I found me an original style 72 steering wheel for my truck, but I can't seem to get the bloody thing on straight.
Is there a mark or anything that I should be using to line it up? If so, can somebody post a pic pointing it out? Thank you, Toad
"The greatest pleasure is to vanquish your enemies and chase them before you, to rob them of their wealth and see those dear to them bathed in tears, to ride their horses and clasp to your bosom their wives and daughters." Ghengis Khan IIOY??? |
12-12-2009, 10:21 PM | #2 |
sharp as a marble
Re: Steering wheel alignment
On some Chevys, if you look at the end of the steering shaft you will see a line. This line will be a strike made by a chisel after the steering wheel was put on and the nut tightened. It is not on all chevys though. Here is my suggestion. If you can remove the steering wheel, do that. Then sit it back on the column loosely. Find a road close to home that you can drive your truck and see how far off from center you are. Stop and slip the steering wheel off and get it as close as possible. Once you have done this it is time for a front end alignment. The final tweek in centering your steering wheel will be a toe adjustment that is part of an alignment
12-12-2009, 11:19 PM | #3 |
When I had my alighnment done they straightened the steering wheel for me and it is perfectly straight.
12-13-2009, 05:20 AM | #4 | |
70 Chevrolet=Obsession
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke! IT'S NOT EASY BEING GREEN! -Kermit the frog 1970 Chevrolet C-10 Longbed Stepside : 350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes) 1996 Toyota Corolla (Parts runner) Last edited by unclewatts; 12-13-2009 at 05:22 AM. |
12-13-2009, 09:38 AM | #5 | |
sharp as a marble
Shoulda went back to the alignment guy! Centering the steering wheel is a part of adjusting the toe. Doing the steering wheel pull thing is easy on our stuff, but later model cars/trucks have a master spline and it cannot be done.
12-13-2009, 12:21 PM | #6 |
Lot's of times through the years parts have been mismatched. If you center the wheel useing the tie rod sleeves you may wind up with the steering out of center. Set the toe-in & check the steering center by the relation of the inner tie rod ends to the frame rails. If that's all done center the wheel like Cpar said & you will have a great driveing truck.
12-13-2009, 05:22 PM | #7 | |
What about inner tie rod ends? Center then on the frame rails??? You got any pictures of this. This sounds like EXACTLY something I am needing to do.
12-13-2009, 10:09 PM | #8 |
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke! IT'S NOT EASY BEING GREEN! -Kermit the frog 1970 Chevrolet C-10 Longbed Stepside : 350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes) 1996 Toyota Corolla (Parts runner) |
12-13-2009, 07:19 PM | #9 |
The reason I asked is because I can turn the wheel like... 3 turns to the right, but only 1 1/2 to the left.
The wheel is pretty much straight on, when driving straight, but I think that through the years, it's slowly been shifting over. Like... somebody replaced original wheel with something else, had it aligned, and it was off a little. Then the next person replaced THAT wheel with a grant steering wheel, had it aligned, and then it was off EVEN MORE. Know what I'm saying? I want to get this back to right. So I think I'm going to pull the steering wheel off, then do this tie rod / pitman idler arm thing and put the steering wheel back on, and then have the "straighten" the steering wheel back up by aligning it. Did that make any sense at all?
