Old 12-13-2009, 12:20 AM   #1
Libertad
No Nonsense
Libertad's Avatar
Removing tension from the leaf springs..help
I am going to take off the rear leaf springs and would like to know where I should jack it up to remove the tension from the leafs. I have a 75' with the 8 leafs that sit on top of the axle.
Bi-Centennial Blazer
Libertad is offline   Reply With Quote
Old 12-13-2009, 12:30 AM   #2
cableguy0
Re: Removing tension from the leaf springs..help
there really isnt any tension of the springs. put jackstands under the frame and the springs will hang. then just unbolt them.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 12-13-2009, 12:36 AM   #3
bigblock73
yeller
bigblock73's Avatar
If the axle is still bolted to the leafs, you need jackstands under the axle as well...otherwise it will fall to the ground when the leafs are unbolted...and could possibly injure anyone under it or around it.
bigblock73 is offline   Reply With Quote
Old 12-13-2009, 01:01 AM   #4
Libertad
No Nonsense
Libertad's Avatar
I already unbolted the rear bolt that connects the hanger to the shackle and the leaf spring shot up and is resting on the bottom of the bed. I loosened up the front bolt and there is too much tension to remove the bolt.
There seems to be a lot of tension on the leafs maybe because they sit on top of the axle? I do have jack stands holding the rear of the truck up under the axles.
Old 12-13-2009, 01:05 AM   #5
KQQL IT
At the body shop.
KQQL IT's Avatar
Jack it up on the frame. Not the axle
Old 12-13-2009, 01:11 AM   #6
cableguy0
your lucky the truck didnt crush you.
Old 12-13-2009, 01:49 AM   #7
Libertad
No Nonsense
Libertad's Avatar
thanks got it now. i have jack stands ounder the axle and frame.
Old 12-13-2009, 12:23 PM   #8
Krilix
Krilix's Avatar
wow...your crazy :O
1986 Chevy 3/4ton 4x4
Lift- 4" front, about 5" in the back
Plans- 3" body lift and hopefully some 38" boggers..
Krilix is offline   Reply With Quote
Old 12-13-2009, 01:11 AM   #9
bigblock73
yeller
bigblock73's Avatar
You need to remove the axle first...or use jackstands under the axle and frame.
I would jack the truck up first by the axle...place the frame on jackstands...then lower the axle some, and place it on jackstands.
