Old 12-15-2009, 08:08 AM   #1
softballnrd27
Always a work in progress
softballnrd27's Avatar
More pics of new truck, need some help
I shot some pics of the engine compartment. Here is the history on the truck: the carburetor that the PO had on it backfired and caught the under hood insulation on fire. That in turn burned up some plugs and wires. In the pictures below you can see the damsge. Only a couple of fires were actually burnt all the way through and a couple of plugs/connectors were melted some. My question is, should I just replace the harness or fix what is wrong with this one?
Motor Shot
Wiring harness shot 1
wiring harness shot 2
Plug for??
Would like input either way and if you say replace it what company should I look in to? I have looked at Ez-Wiring and they seem to be the cheapest, are they good quality?
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 12-15-2009, 09:49 AM   #2
68 TT
Still plays with trucks
68 TT's Avatar
Re: More pics of new truck, need some help
No big deal to fix what you have but a new harness isn't that much money. Depends on how much time/money you have to spend on this project.
If you are on a tight budget so a new harness is out of the question and / or can't find a used one that is correct find a GM vehicle of the same vintage and buy that used harness. You can repin the firewall connector with the wires from the donor harness that you need.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
