Old 12-16-2009, 08:23 PM   #1
tonypaul
tonypaul's Avatar
Trim measurment
I got all new upper and lower trim for my gmc swb. The truck didnt have trim orginally. The bottom should be easy to figure out because I can use the fenderwells to get it started. If I laid something flat on the flat part of the bed, and measured down to the top of the trim- what is the measurment? How many holes in the bed and what size are the holes?
Thanks guys!!!!!!
My baby is getting sprayed during the xmas holidays!!!!
tonypaul is offline   Reply With Quote
Old 12-17-2009, 09:37 AM   #2
JimKshortstep4x4
Re: Trim measurment
The top bed trim is not parallel with the top of the bed so you end up with X-Y coordinates. The Assembly Manual has the dimensions if you have one.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 12-17-2009, 11:58 AM   #3
tonypaul
tonypaul's Avatar
Re: Trim measurment
Thanks for the info. How about a measurment from the top of the bed at the front and then one at the back of the bed? Where could I get this book thats mentioned?
Old 12-17-2009, 12:14 PM   #4
OhOneWS6
OhOneWS6's Avatar
Re: Trim measurment
Early Classic has them. Just search their online catalog for Assembly Manual.
OhOneWS6 is offline   Reply With Quote
Old 12-17-2009, 01:08 PM   #5
Hart_Rod
Hart_Rod's Avatar
Re: Trim measurment
Take a look at this:
http://67-72chevytrucks.com/vboard/s...=1#post1971270
Hart_Rod is offline   Reply With Quote
Old 12-17-2009, 04:13 PM   #6
tonypaul
tonypaul's Avatar
Re: Trim measurment
Originally Posted by Hart_Rod View Post
Thanks! I knew atleast one other person had to go through this proceedure. The only real problem I see now is that if your bed has to be on the frame at the time you mark it out, which is no real big deal but I was going to do the trim on the bed while the cab was in paint. And the bed needs to be in perfect position to get the 30" line. If your frame or bed is not got twisted a little over the past 40 years or so it should be pretty easy.... I wish I would have waited to take off the bed now....
THANKS AGAIN!!!!!
