12-18-2009, 02:56 PM | #1 |
67-72 steel floor in a 60-66
Finally got one, it was a long bed but outlawc and I cut it down to a shortbed. Thanks for your help outlawc!! It fits very good, will have to redrill some holes to bolt it to the bed though. Here are some pics.
12-18-2009, 03:26 PM | #2 |
Re: 67-72 steel floor in a 60-66
I have mine sitting in storage waiting for the swap. Looks good.... Anything of note that might prevent problems during the swap?
12-18-2009, 04:20 PM | #3 |
The front bed panel will have to be modified. Since the wood was 3/4 thick, the flange will have to be cut and moved up then welded. I also had to trim this area (in pic) for the sides to fit right. Other than that it wasnt to bad.
12-18-2009, 04:48 PM | #4 |
Nice work!!!!
CHEVY ONLY |
12-18-2009, 05:36 PM | #5 |
Thanks Joe! I need to get some these from mar-k so I can get it bolted up.
GM 58-66 FLEETSIDE INNER WALL REPAIR PANELS |
12-18-2009, 06:09 PM | #6 |
I'm raising the floor so the front panel is getting modified regardless; I'll watch out for that rear corner now that I'm informed (Thanks!).
I did buy a MarK smooth front panel for the 68 so I might see if it would work as well.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 12-18-2009 at 06:09 PM. |
12-18-2009, 06:33 PM | #7 |
I have a 67-72 front panel here and its different at the top in the corners to the 60-66 panels. I thought about using it also.
12-18-2009, 06:39 PM | #8 |
Did the 67-72 bed floor bolt right to the 60-66 frame stock locations?
Thanks Tony from Norcal |
12-18-2009, 06:53 PM | #9 |
No it did not. I will have to drill some new holes.
12-18-2009, 11:05 PM | #10 |
Yeah you should be good!
12-19-2009, 01:47 AM | #11 |
60-66 Nut
That looks good......now I just need to find one that isn't beat to crap.
12-19-2009, 09:37 AM | #12 |
Yeah i was lucky, mine wasnt too bad. In the back it was beat up, but after the 8 inches were taken out it took out most of the bad area.
12-19-2009, 10:12 AM | #13 |
Hollister, CA.
Looks good man...thanks for share the info !!
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
12-19-2009, 11:10 AM | #14 | |
Yes, they will bolt right up. No problem Chief. |
12-07-2012, 05:42 AM | #15 | |
Looking back, it may have been a bigger job of fitting had it been a fleetside or a longbed. HTH, sam |
12-19-2009, 10:13 AM | #16 |
1961 crewcab
looks nice, did the wheel tubs and sides bolt on , or did you have to drill?
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
12-30-2009, 07:01 PM | #17 |
Here are a few pics. Enjoy!
12-30-2009, 07:06 PM | #18 |
NICE!!
thanks for the pics!!
CHEVY ONLY |
12-07-2012, 02:13 AM | #19 |
I am going to do this with mine. Thanks for sharing.
12-07-2012, 08:31 AM | #20 |
No problem.
