12-18-2009, 05:10 PM | #1 |
LS Power Steering Pump Puller/Installer
Hi looking to find out what size threads are on the internal shaft of a 2007 5.3 power steering pump
The Puller/Installer kit I have only has 3/8" I got the power steering pulley off now need to find the correct installer bolt size to put it back on? Thanks
Rolled the dice and lost!! Check Out my 71 build http://67-72chevytrucks.com/vboard/s...d.php?t=375158 |
12-18-2009, 05:50 PM | #2 |
Re: LS Power Steering Pump Puller/Installer
Just a guess but a lot of stuff is 10 X 1.5mm. Have you tried any of the bolts that held the pump and brackets on?
12-18-2009, 05:58 PM | #3 |
Just wondering if this would be Metric?
12-18-2009, 06:17 PM | #4 |
I think I found what I was looking for?I have not yet check out the numbers on the pump.
Hope this might help out someone else! All threaded holes in a metric pump are 10 x 1.5, while SAE pumps are 3/8 x 16. You can distinguish a metric pump from the SAE pump by the last 2 digits of the number that is cast in the side of the pump. The last 2 digits of a metric casting number are 47, while SAE pumps are 19. Make sure you check this out. If you thread an SAE bolt into a metric pump, it will seem to start ok, but when you try to tighten it, it will crack and destroy the pump case.
12-18-2009, 06:24 PM | #5 |
Yup like I said most likely 10 X 1.5mm. The assecory brackets, motor mounts lots of the bolts are 10 X 1.5. Should be able to find something that works.
12-18-2009, 06:32 PM | #6 |
Thealien Now I need to locate a metric installer bolt.....
