Rear diff gear options for 3/4 ton
Hello all, I just picked up a 78 3/4 crew cab. Im wanting to swap gears in the rear diff due to them turning high rpm's at highway speeds. What are my options w/out installing a 700r4 for overdrive?
Thanks |
Always trouble
Re: Rear diff gear options for 3/4 ton
My 86 3/4 ton has 3.23s in it.
91 Silverado Regular cab, 2wd, swb-project truck 97 Silverado Extended cab, 2wd, swb-driver |
I think GMC91 has the highest gears available... I was looking at that a while back for my 78 c20 and the highest I could find was 3.2x gear set.
Always trouble
With that being said, how will this truck do with a TH350 on the intersate? Or would my best bet be to find a TH700r and have it rebuilt?
Always trouble
My 86 came with it when I bought it.
I found it on a web site that sells ring gear/pinion sets. I tried to find it again and I can't find it right now. It was hard to find and I think I only found 1 or 2. Seems anything higher than a 3.73 is uncommon and hard to find.
There's stuff for a 14 bolt 9.5 semi floater axle but you should have a 10.5" 14 bolt full floater in a '78. Keep hunting, it's out there somewhere. If i was going to swap trannys at all, I'd put a 700r4 in it. But I wouldn't use a 700r4 with just a stock rebuild if you are going to do much hauling or any towing with it. Last edited by 78 Chevyrado; 12-21-2009 at 06:08 PM. |
swap to a 700r4 youd like it better a 3 to 1 first gear and od and it has four gears instead of 3 itd be better in the long run
mitch 87 chevy short box 4wd tbi 350/built 700r4/np208 3.73s |
Always trouble
When I get this truck finished, it aint gonna haul or tow nothing, never gonna see mud either, its strickly a daily driven show truck.
Truck Nut
![]() Join Date: Jun 2007
Best luck is to check a local wrecking yards and start counting teeth in the rear diff. Also, trucks with the smaller brake drums usually have a numerically lower gear ratio, thats what I was told. I am going to just change out my rear diff. Maybe I will be lucky and find a 3:23!!! I have a couple of them already. Just gotta start counting.
Tony Kee Texas Square Bodies |
diesels usualy came with the high gears in them.
![]() 1949 Five Window, 1973 Step Side, 2000 Z71 |
Gettin It One Pice At A Time
why did they put such low ratios on the 3/4? because according to my SPID my 1/2 comes with 3.73's!
RIP ELJAY ![]() ![]() Getting the truck done, one piece at a time. “You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan “I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby |
