12-22-2009, 10:57 AM | #1 |
Under Construction
BBC vs. SBC front springs
curious if anyone knows the height different in the two springs due to different spring tensions in the two. I left the bbc springs in the front when we installed the front end from the donor truck. I need to bring it down some more, but curious what the standard sbc springs would do drop wise, so i could go from there. I am thinking i need to get it down another two inches. I currently have ece 2 1/2 drop spindles and the stock bbc springs.... I am thinking the truck would drop about an inch if i switched to the standard sbc springs. I will look into a 1 - 2 inch drop spring. just wanted too see if i was slightly on track.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 Last edited by my67chevytruck; 12-22-2009 at 11:15 AM. |
12-23-2009, 01:19 AM | #2 |
Re: BBC vs. SBC front springs
I don't have a technically definitive answer.... but I would guess the sbc springs when compared to bbc springs (holding up an equal amount of weight > than a sbc) would be shorter in overall height. Your ~1" estimate sounds about right to me.
12-23-2009, 01:08 PM | #3 |
Under Construction
Thanks Scoti I will go from there...
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
12-25-2009, 03:44 PM | #4 |
What are you running? A bbc or a sbc? The springs sitting side by side out of the truck are the same height. The Difference is the spring rate. I went the the opposite way of what you are doing. I have a SBC and installed BBC springs. It gave me about 2 inches of lift. If you are running a BBC and want to install SBC springs. it may give you more than the 2 inches drop because of the weight difference between the two motors.
www.cardomain.com/id/pooz911 |
12-30-2009, 12:04 AM | #5 |
1-2 is about right. they will defently ride different thought.
bbc with sbc springs tends to be bouncy and soft. the ride realy firmed up when i put the sbc in it. |
12-30-2009, 12:14 AM | #6 |
Under Construction
i am running a sbc, but the donor was a bbc truck
