![]() Join Date: Jul 2006
Cigarette lighter toasting phone charger??
Previously I had a sprint nextel phone and used the car charger all the time with no problems. Now I have a samsung sprint phone and I've toasted three car chargers after about a days worth of use. The only thing I can think of that might be causing this is possibly my MSD interference? Any ideas?
Thanks. |
Gearhead and audio junkie
Re: Cigarette lighter toasting phone charger??
Hmm well first I'd check the voltage coming off the cig lighter, should be around 14.4v or so if it's like 2 volts over, you probably would toast it. Some chargers are also made more heavy duty than others, most of the charger designers assume everyone drives today's cars with excellent voltage regulation and all that jazz. Bad voltage regulator possibly? If you shut off your lights or a high drain appliance it could cause a voltage spike which could toast a charger too.
Active Member
![]() Join Date: Jul 2007
Yeah, the truck may be overcharging. My voltage is just over 13 vdc measured at the battery while running. Some cheaper chargers are not designed to take much over 12.5 to 13.5 volts while others have overvoltage protection.
I have a new AC Delco alternator(external regulator) and I'm usually dead on 14.1 with no load. I haven't checked the voltage at the lighter but it has to be the same however I will verify. Yah my last phone was a nextel built to military spec so I assume the charger was beefed up also. I guess I could wire in a voltage regulator for the cigarette lighter.
