Old 12-22-2009, 05:46 PM   #1
Silence86
Silence86's Avatar
oil from my header
ok so lately my truck has been running funny, today i went to change a header gasket and i noticed oil from the front hole where the header is. anyone know what might be causing this? its a mall block 350.
1986 gmc sierra....http://67-72chevytrucks.com/vboard/a...hp?albumid=622
Silence86 is offline   Reply With Quote
Old 12-22-2009, 05:57 PM   #2
Adams74Chevy
Adams74Chevy's Avatar
Re: oil from my header
The oil is in the exhaust port of the head? Just trying to clearify, not be a questioning donkey. I'd check compression on that cylinder too.
2006 Silverado Crew Cab 1500 4x4 5.3L automatic
1986 M1008 CUCV 6.2L Detroit Diesel TH400 4.56 Detroit Locker rear NP208
1973 K20 "Silverado" 350ci, HEI, TH350, NP203 with 2wd conversion, A/C, power windows,tilt wheel, dual tanks. My '73ish K20 thread My 5yo son claims it as his.
1987 V20 Custom Deluxe 350 TH400 NP208 "farm truck" getting parted out.
2016 Nissan Altima grocery getter/commuter
Adams74Chevy is offline   Reply With Quote
Old 12-22-2009, 06:00 PM   #3
Silence86
Silence86's Avatar
yeah, i have no idea about engines man
Old 12-22-2009, 06:04 PM   #4
Adams74Chevy
My mechanical brain has rotted over the past 10 years from not working on vehicles on a regular basis. I'd say it could be head gasket, rings, valve seal, or something else I'm forgetting. Note: I'm not saying it's a definate on any of them but they are the most lively culprits.
Old 12-22-2009, 06:09 PM   #5
Silence86
Silence86's Avatar
is it expensive?
Old 12-22-2009, 06:13 PM   #6
Adams74Chevy
It depends on what is the problem. I'm sure there are some others on here that can give better ideas and help troubleshoot it. You may even want to post this in the Engines forum, it may get more reads and info.
Old 12-22-2009, 06:18 PM   #7
Silence86
Silence86's Avatar
will do thank you
Old 12-23-2009, 12:14 AM   #8
3r!c84
Badass
3r!c84's Avatar
do it smoke (white smoke) when you start it up and then stop? or just keep smoking out the tail pipe?
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 12-29-2009, 05:45 PM   #9
Silence86
Silence86's Avatar
its smokes when i start it up and when i come to a stop.
Old 12-29-2009, 05:55 PM   #10
bikes&bowties
bikes&bowties's Avatar
Your piston rings and valve seals are most likely the culprits...
bikes&bowties is offline   Reply With Quote
Old 12-29-2009, 05:56 PM   #11
68 TT
Still plays with trucks
68 TT's Avatar
So it is the front bolt that attaches the header to the cylinder head that is leaking oil?
These are blind holes so the only way that could happen is to have a cracked cylinder head. Somebody may have put a bolt in there that was too long and tightened the snot out of it trying to get it to seat the header.
You may be able to just put some ultra black or copper RTV on the bolt threads and stop the leak into the headers.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 12-29-2009, 05:53 PM   #12
qu1cks1lver56
qu1cks1lver56's Avatar
id say rings probably
qu1cks1lver56 is offline   Reply With Quote
Old 12-29-2009, 05:56 PM   #13
Silence86
Silence86's Avatar
are they replaceable? sorry, i know nothing about engines and im at a loss. i start school on monday and am hoping to get this resolved by then
Old 12-30-2009, 12:37 PM   #14
pig rig
pig rig's Avatar
well it sounds like a good time to learn and if you got a unheated garage to work on it your better off then some of us that have to stand out in the freezing rain just to keep our trucks running
Im going out to lay on the frozzen ground to put a starter in and I'm happy
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette
http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG
pig rig is offline   Reply With Quote
Old 12-30-2009, 01:04 PM   #15
68 TT
68 TT's Avatar
I am assuming you have no air compressor so your best bet is to buy a screw type valve spring compressor. It will clamp over the top of the spring & retainer and compress the spring to the point you can remove the locks & retainer so the spring can come off. Something like this:
http://www.summitracing.com/parts/OTC-4573/?image=large
You will need to put something into the cylinder to keep the valves from falling into the hole. Compressed air works but assuming you don't have an air compressor you can use nylon ski rope or even an old extension cord shoved in through the spark plug hole. Turn the crank bolt over until the piston stops against the rope then you can pull the valve springs on that cylinder without dropping a valve.
Tap the top of the retainer with a rubber mallet before you try to remove the spring. This will break the retainer free of the locks. They get stuck together pretty good sometimes.
Old 12-29-2009, 06:00 PM   #16
Silence86
Silence86's Avatar
no not the bolt hole. just the big hole where air flows through the header.
Old 12-29-2009, 06:02 PM   #17
bikes&bowties
The way I read it. He was talking about oil residue in the exhaust port. And with the way he says it smokes on start up and when its running it makes me think a mixture of valve seals and piston rings.
Old 12-29-2009, 06:05 PM   #18
Silence86
Silence86's Avatar
which is easier to check? and how do you do this ?
Old 12-29-2009, 06:24 PM   #19
68 TT
68 TT's Avatar
A compression check will be the quickest and easiest test to do.
If all the cylinders are within about 10% of each other then a leak down test is next to see if you have other compression related issues like a damaged ring, piston or valve. If the compression and leak down tests are consistent then it is most likely just bad valve stem seals.
With the age of our trucks you are guaranteed to have old petrified damaged and non-functional valve stem oil seals but the guides themselves may be in decent shape. My truck smoked a little on start up before I changed out the valve stem seals and now it doesn't smoke at all.
Get a set of 16 silicone umbrella style valve stem seals that have springs around the top edge to hold them tight to the valve stem. While you are at it get a set of Z/28 replacement valve springs. They should cost you about $40 out the door for the seals and springs at your local machine shop.
It's not the easiest job to do with the heads on the truck but it can be done.
Old 12-29-2009, 09:29 PM   #20
3r!c84
Badass
3r!c84's Avatar
its a valve seal..if it only happens at start up.
-00 Saturn 5spd
1/4:13:90
Old 12-29-2009, 09:37 PM   #21
Silence86
Silence86's Avatar
ok any one got any pics of this? or an explanation to to replace?
Old 12-29-2009, 09:47 PM   #22
3r!c84
Badass
3r!c84's Avatar
umm no i dont,its in the head what the valve rides into is leaking.its like a .25$ part but a longass time to replace it lol..trying to figur out the new change in this website!!!?
-00 Saturn 5spd
1/4:13:90
Old 12-29-2009, 09:49 PM   #23
Silence86
Silence86's Avatar
hahaha dang this sucks. i hope thats it. would this cause it hen im driving to be more sluggish? cause it donmt feel like i have the power i had before i had this problem?
Old 12-29-2009, 09:51 PM   #24
3r!c84
Badass
3r!c84's Avatar
no it shouldnt realy change that..i had a atc that would smoke out the garage when i first fire her up.it would only smoke for 2 mins and then run good
-00 Saturn 5spd
1/4:13:90
Old 12-29-2009, 10:20 PM   #25
Silence86
Silence86's Avatar
dang. this suck.... , i also hear a tickin coming from inside of my valve cover
