12-22-2009, 06:57 PM | #1 |
Z frame and PB dropmember???
ok im getting ready to start my air suspension on my 68 swb. the previous owner started a Z on the frame, its just spotwelded not complete. he did about two inches and i was wondering if i can complete the 2 inch Z and then install a dropmember. i want the narrow track with and the centered wheel the DM provides. i have owned the truck for about 3 years and purchased an Ls1 last week for it so the frame needs to get done. i plan on running 24in wheels all around and want it as low as possible. thanks for all input.
12-22-2009, 07:30 PM | #2 |
A guy with a truck
Re: Z frame and PB dropmember???
There was one other truck done(started?) this way. I think you'll at least have to run stock spindles, though I dunno w/ fours- depends on tire size... Depending on where the cuts were made, everything should line up. You will have cab/trans clearance problems for sure..
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
12-22-2009, 08:43 PM | #3 |
low n' slo
why dont you cut it back off and weld it back to stock?
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
12-23-2009, 03:56 AM | #4 |
CHECK OUT THIS THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=258916
70 SWB STEPSIDE 70 BLAZER 09 challenger |
12-23-2009, 03:58 PM | #5 |
thaks for the input guys. the reason for not re-welding it back to stock is i figure i will be able to run 24's and still get damm close to the ground. i understand the hood will be an issue but unless i find or u guys tell me of any other major issues i want to give the 24,s a try. what are any disadvantages mof running stock vs drop spindles?? thanks guys.... pics coming soon
12-23-2009, 04:12 PM | #6 |
Will you get enough lift to turn only thing i can think of
