Old 12-24-2009, 12:15 AM   #1
Colesnsty68
Colesnsty68's Avatar
Rearends
So basically all i want to know is what rear ends will work with a 77 frame. Any rearends, outta of anything. Just really want to know so i can start looking. its a half ton, 2wd so its a 5 lug. Thanks.
1970 Chevrolet custom camper 20
2000 F@$d F250 Powerjoke
"And i still like bologna on white bread now and then" -Alan Jackson
Colesnsty68 is offline   Reply With Quote
Old 12-24-2009, 02:01 AM   #2
2tons of fun
Re: Rearends
you can get a 10 and 12b that will bolt in or you can fit any rear your heart desires if you can do basic weld/fab.
2tons of fun is offline   Reply With Quote
Old 12-24-2009, 08:55 AM   #3
78-5.3
78-5.3's Avatar
Re: Rearends
i was wondering the same thing but i didnt mind movng the pads just didnt wanna cut axles
78-5.3 is offline   Reply With Quote
Old 12-24-2009, 06:24 PM   #4
Colesnsty68
Re: Rearends
does anyone know the length?
Old 12-24-2009, 09:10 PM   #5
78-5.3
78-5.3's Avatar
Re: Rearends
1970 camaro
Axle tube flange to axle tube flange: 55.25"
Year & Model Axle Length Notes
1965-1966 Mustang 57.25 inches
1967-1970 Mustang 59.25 inches
1971-1973 Mustang 61.25 inches
1977-1981 Versailles 58.50 inches
1967-1973 Mustang, Torino, Ranchero, Fairlane 59.25 inches to
61.25 inches
1957-1959 Ranchero and station wagon 57.25 inches
1966-1977 Bronco 58 inches
1977-1981 Granada/Versailles 58 inches
1967-1971 Comet, Cougar, Mustang, Fairlane 59.25 inches
1964 Falcon 58 inches
1967 Cougar 60 inches
1967 Fairlane 63.50 inches coil springs
1972 Ford Van 3/4 ton 68 inches
1973-1986 Ford Van 3/4 ton 65.25 inches
57.25 inches
narrowest 9" housing
1966-1977 Bronco 58 inches 5-on-5 1/2 inch diameter bolt circle
1967-1973 Torinos, Rancheros, Fairlanes 59.25 inches or
61.25 inches
1967-1971 Comets, Cougars, Fairlanes 59.25 inches
1974 Maverick 8" 56.50 inches
one GM the rest is FORD
Rear Axle Measurements
MEASURED ACROSS WHEEL MOUNTING SURFACE
56 1/2" 71-77 Ford Maverick 8",
57" 1975 Mustang II 8" 71-74 V-8 Mavericks 8", All '75-77 6's & 8's Maverick 5 Lug 8", 49-51 Ford, 57-59 Ford 9"
57 1/4" 64 1/2 - 65 Mustang
58" 78-88 Mid sized GM Car, Malibu/Monte Carlo (82 up Metric Studs), 80 Granada & Lincoln Versailles,
67-70 Mustang/Cougar/Fairlane, Regal with 10 bolt axle, S-10 P.U., 65-67 Nova
58 1/2 " Ford Grenada
59" 68-83 Corvette
60" 55-64 Chevy Car, 67-69 Camaro, 64-67 Chevelle, 68-74 Nova, 71-73 Mustang/Cougar, 84-95 Corvette
60-61" 64-69 1/2 ton 2wd Chevy/ Some GMC 6 lug rear end 12 bolt Coil spring set up Possible gear ratio's 3.70
62" 64-77 Chevelle, 73-76 Torino, 89 Trans Am,
70 2wd 6 lug rear end 12 bolt Possible gear ratio's 3:08, 3:40, 3:73
70-81 4wd 6 lug reared ...............................................................
71- Newer 2wd trucks use a 5 on 5 lug pattern
71-76 Full Size Cars " "" "" "
60" 60's GMC and some Chevy's Dana 44 or Dana 60 with leaf springs 6 lug, Gear ratio's 3.21 to 3.92. GMC V-6 used a 3.21 Dana 44 used a standard chevy 1310 yoke, Dana 60 used the heavy duty yoke which takes the larger 1350 yoke.
anyone else got widths
