Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > Welcome Area
Old 12-24-2009, 01:26 PM   #1
ravens65
ravens65's Avatar
hello fellow truckers
new to the site but not to the seen . the motovation.....
edelbrock aluminum headed ( mild port job), .060 over 4 bolt , cloyes true roller rockers-1.6 ratio, 383 stroker 450hp @5800 rpm- 468fp tork @ 5100rpm , headman headers ,edelbrock 750 carb ,speed pro 10.3 to 1 pistons, childs&albert-zz gapdura moly rings ,eagle steel crank,durabond cam bearings, comp cam-custom series , comp-chrome moly push rods, gm/pink forged rods, arp bolts, dyna gear race oil pump&pick-up, fel pro blue gaskets - built by A.R.Racing/performance runs on 91 octane (now if I just had a twin turbo!!)
the truck has way to much to list , but look at the leather covered dash & headliner- buckets out of a cadillac srx , tubular a-arms , Ididit alum. column, tub job , was a frame off , nut and bolt rod-storation its now flat black ( looks so wicked!) and has a Trans /Am rear end - 4 wheel disk brakes , front and rear sway bars , fast ratio power steering box (3 turns lock to lock )also has a flip hood - to see the motor click on my avatar ....any questions??? Eric
If it has tits or wheels its gonna give you problems!!!
ravens65 is offline   Reply With Quote
Old 12-24-2009, 02:41 PM   #2
CHEESE
The Cheesiest
CHEESE's Avatar
Re: hello fellow truckers
welcome to the site! nice project! you will find this site to be your new home away from home!
CHEESE is offline   Reply With Quote
Old 12-24-2009, 05:37 PM   #3
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Hey welcome to the best board around from MT! Sick looking truck man I like what you have done with it. Keep up the good work. I bet its a blast to cruise around in
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
