12-25-2009, 02:43 PM | #1 |
87 silverado dual gas tank problem
I recently bought a 87 1500 sivlerado and its a really cool truck and I am going through fixing the few things wrong .The question is the dual gas tanks .It only works when on right tank and if I switch it to left it will not run .What is my best plans of fixing the problem .Is it most likely the switch or what ?
12-25-2009, 05:30 PM | #2 |
Robert Olson Transport
Re: 87 silverado dual gas tank problem
check the power to the sides through the switch then if you have power there check to the fuel pump in the tank... i assume its the electric fuel pump with an EFI motor
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
12-25-2009, 05:36 PM | #3 |
Cruzzzn' Vet
Had the same problem, replaced the switch and it works as advertised
12-25-2009, 06:58 PM | #4 |
I had the same problem with "Bob", but the PO didn't worry about it and left half a tank of gas in it...for a LONG time. So I had to buy a new tank, pump, fuel level sending unit and the only part that was actually bad...the switch in the dash. I bought all of the parts from Rock Auto. I would tell you to replace the switch with a AC Delco switch not some no name one. It was only about $10 shipped to my house from them.
Good Luck, and you will love that truck. |
12-25-2009, 08:17 PM | #5 |
Thanks guys .Should the guage still change if its the switch cause when I change the switch over the guage does not change either .I will try the switch first cause it does seem too loose so I am hoping its just that .
12-26-2009, 10:23 PM | #7 |
what is best way to get the switch off properly ?
12-27-2009, 04:48 AM | #8 |
In the Forgotten far North.
It just snaps into place in the dash. If you want to remove it with the least amount of damage to it or the dash you'll have to gain access to the back side of it by one of 3 methods.
1. Reach up under the dash while laying on the seat and push up & out on the bottom of the switch. Then reach up to the top of the switch and push down & out. 2. Remove dash bezel & dash pad. If'n ya have a/c, move the center duct out of the way and reach into the back side of the dash to squeeze the top & bottom together and push the switch out. 3. Remove the bezel remove the radio reach inside and pop it loose from there. While #1 is the simpler one, if'n yer a big guy with big hands & armsit can be a real P*I*T*A Personally I prefer going after it as described in #2.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
01-05-2010, 09:48 PM | #9 |
Well I changed the switch and it still does not work .
What is next best thing to check ? |
01-05-2010, 10:20 PM | #10 |
Check your grounds mine has the copper ground strap snapped.
***My 84 short bed build up***** http://67-72chevytrucks.com/vboard/s...68#post3481968 |
01-05-2010, 10:31 PM | #11 |
not to sound ignorant but where should i look for the ground wire
01-06-2010, 12:39 PM | #12 |
Moderator
If it's the same as the `85 trucks it should attach to the ring on top of the tank around the sender.
01-06-2010, 02:24 PM | #13 |
^^^Hatzie is right, and it's a bit$h to get to. I actually had to drop the tank to check mine. While I had it out I put power and ground to the pump to see if it was working...it wasn't.
01-06-2010, 10:30 PM | #14 |
I can join the club. My driver side tank work and when i throw the switch to the pass, the fuse blows. Any pointers.
01-07-2010, 05:02 AM | #15 |
I am going to wait till I get new fuel pump cause I do nt want to drop it twice .I might as well cahnge everything it might be cause this has always been a issue and I want it fixed once and for all.
The switch blowing problem was on mine abreaks in wires and when switched they would arc .I suggest you check the wires cause I bet that what it is . |
05-07-2010, 11:35 PM | #16 |
I had the same problem. I had the bed off so I put power to the pump right at the tank and it turned on. After diagnosing the problem, it ended up that the cross over valve was bad. It sits right next to the right tank. The cost is about $95 for the part.
05-07-2010, 11:38 PM | #17 |
Now for my new tank switch problem. As I stated in an eariler post, both tanks are working great now. Problem is, when you switch tanks with the engine running, if you happen to only move the switch half way, it shuts the engine right off. Then switch it up or down it fires back up. Is this a bad switch? Is this switch hooked to some kind of engine cutoff?
05-08-2010, 12:28 PM | #18 |
If the switch is in-between positions, then neither fuel pump is getting power, so your engine is starved for fuel and shuts off.
05-08-2010, 02:35 PM | #19 |
18 Till I Die
Yea my daughter get in and sometimes she bumps the switch and it just cranks. Thats the first thing I look at "did she hit the switch" and evertime the switch is sittin in the middle.
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... |
10-28-2015, 07:46 PM | #20 |
nvm
