Old 12-26-2009, 07:34 AM   #1
SeaWolf0217
first crew cab
hay guys im new hear iv got a 72 3/4 ton 4x4 but im wanting to build a bagged crew cab next any sugestions like what fram i could use im lookn at use a 5.9 cummins as the power plant any help will be really helpfull
SeaWolf0217 is offline   Reply With Quote
Old 12-27-2009, 12:22 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: first crew cab
welcome to the board sea wolf.
What are you going to use for a crew cab? One of the ones converted back in the day and sold through the GM dealers, or are you looking to fab one up?
Old 12-27-2009, 01:04 AM   #3
SeaWolf0217
Re: first crew cab
probable ganna fab one using two cabs it would be a lot of work but possible
Old 12-27-2009, 11:30 PM   #4
brothers69c-10
Suburban Hick
brothers69c-10's Avatar
Re: first crew cab
I would use a 3/4 or one ton frame and the njust lengthen it. If you look at the frames of a 1/2 ton and 3/4 ton there is significant difference under the cab area on how thick the rails are. Then i would brace it of course. 5.9 cummins is a great idea for a powerplant. Dieselwrencher swears by those things. Also there was a member on here up in oregon who had a crewcab for sale a while back, with suicide doors if i remember correctly.
Mathew
1947 Chevy 3600
1951 GMC 100
1969 Chevy C-10 396/500hp TH400 lowered 4"
1968 Imapla Custom 396/325hp TH400 "Grandmas Car"
1976 Crew Cab 4x4 diesel http://67-72chevytrucks.com/vboard/s...d.php?t=488505
1978 Chevy K-10 454
1983 S10 4x4 "Bumblb" (Grandpa's truck)
1993 Chevy S10 V8 conversion
1990 Ford Probe Gt
1992 Dodge W-150 "Old Man's Truck"
1992 Pontiac Grand Prix SE
1992 Mercury Grand Marquis-Mercruiser
2000 Ford F150 (Currently my mother drives this)
1946 Farmall H with Stan Hoist loader
1965 John Deere 110
1961 Wheel Horse " Rat Tractor"
brothers69c-10 is offline   Reply With Quote
Old 12-28-2009, 12:17 AM   #5
extd56
extd56's Avatar
Re: first crew cab
Lots of work and not sure I would want to go back down that road. I have a decent crew cab truck here in Vacaville you could check out. There are a couple of crew cab lurking on the board here that look really good.
extd56 is offline   Reply With Quote
Old 12-28-2009, 09:35 PM   #6
Sinisterspeed
Sinisterspeed's Avatar
Re: first crew cab
I like the mirror set up on that truck.. I been wrestling with what to do for quite some time. I welded up all the holes in my doors when it was painted. I was thinking of taking newer flip up dodge mirrors and using the corner piece when you install one piece windows to mount them on.. BUT, i have yet to put my doors together because I had not decided to go that route for sure. (one of those things I wish I would have figured out before paint) However, since I have all the parts to rebuild my window glass with all new rubber and felt and I like the looks of this....... Maybe I found my answer!
There are two kinds of people, those who finish what they start and so on.
70 GMC Longhorn (A.K.A Money Bucket)
57 Chev 3100
05 Chevy LLY Dmax.
67 Chevy Camaro
Dad's Budget Build 55
My Longhorn Build
Sinisterspeed is offline   Reply With Quote
Old 12-29-2009, 06:46 PM   #7
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Re: first crew cab
Thats the nicest crewcab I have seen done, Beautiful!! I didnt realize you were that far along with it..any more pics of it??
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 12-30-2009, 12:52 AM   #8
tdave00
Restoring a 68 SWB
tdave00's Avatar
Re: first crew cab
Very nice! Haven't seen it since you got it painted.
tdave00 is offline   Reply With Quote
Old 12-28-2009, 12:23 AM   #9
Longhorn Man
Re: first crew cab
1/2 ton and 3/4 ton frames are pretty much the same. I would start with a one ton.
Old 12-28-2009, 12:27 AM   #10
extd56
extd56's Avatar
Re: first crew cab
I would agree as my truck is on a 79 1 ton frame and the frame is huge.
Old 12-28-2009, 07:29 PM   #11
brothers69c-10
Suburban Hick
Re: first crew cab
There is siginificant difference between 1/2 and 3/4 ton frames. Yes i would recommend a 1 ton frame but top to bottom on a 1/2 ton frame under the cab is about 6 inches and on a 3/4ton frame its about 8 inches and they are usually a little thicker.
Mathew
1947 Chevy 3600
1951 GMC 100
1978 Chevy K-10 454
1990 Ford Probe Gt
1965 John Deere 110
Old 12-28-2009, 10:34 PM   #12
Hart_Rod
Hart_Rod's Avatar
Re: first crew cab
No diference in 1/2 T and 3/4T frame other than some bracing and suspension.....Now the difference between a those two and a 1 T frame is pretty significant.
Hart_Rod is offline   Reply With Quote
Old 12-29-2009, 05:10 PM   #13
Longhorn Man
Re: first crew cab
Exactly. Unless the 3/4 ton in question is a longhorn then the 3/4 and 1/2 ton frames are the same. Some added braces, and lower rear cab mounts.
A longhorn is built on a one ton frame, so it falls under the one ton specs, with a taller, and thicker metal used for the frame rails.
All this is 67 - 72 specific... anything built after that I can not comment on.
Old 12-29-2009, 03:02 AM   #14
SeaWolf0217
Re: first crew cab
i was thinkn about using a four door frame like some of you had said. i dont have a problem fabin up the cab but were would i cut the cabs im wanting to try and run pillerless doors iv got some ideas on that. like suicide rear doors and iv'e heard that there are diffrences in chevy and gmc frames is that true?
Old 12-29-2009, 05:48 PM   #15
71swb4x4
71swb4x4's Avatar
Re: first crew cab
No, it's not true. Frames will differ in the rear if they have coil springs or leaf springs, but Chevy and GMC could have either suspension.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 12-29-2009, 11:51 PM   #16
63chevyll
gets board easy.......
63chevyll's Avatar
Re: first crew cab
have fun, seems to be a popular build these days
63chevyll is offline   Reply With Quote
Old 12-30-2009, 01:17 AM   #17
extd56
extd56's Avatar
Re: first crew cab
Thanks for the kind words, I will be posting some more pictures in the next couple of days.
