Cross Over steering
Looking for anyone who can help me w the proper measurments for cross over steering on a Dana 60 thats going under a 68 4 wheel drive GMC. Need the lengh of the cross over bar? Whats needed and how do I measure. Thanks for the help.
Re: Cross Over steering
I have it done. Using a tie rod link. I can get you some pictures and measurements if you need them. Just let me know what ones
There are two kinds of people, those who finish what they start and so on. 70 GMC Longhorn (A.K.A Money Bucket) 57 Chev 3100 05 Chevy LLY Dmax. 67 Chevy Camaro Dad's Budget Build 55 My Longhorn Build |
http://67-72chevytrucks.com/vboard/s...light=steering
there are some pictures I posted of it some time back.. Mine is the one with the red frame. Let me know if thats what your looking for. its a 60 front under a 70 GMC
to many variables to just give you a number.
put your wheels straight, the steering box straight measure hole to hole. |
Thanks. I found an easy way to do the measuring. U take your pitman arm and push it all the way to the right and then turn your tires all the way to the right and you take a measurment from hole on pitman arm to hole on your upper steering arm located on passenger side of truck. Then you repeat the same process to the left and take a measurment. The 2 measurments will be slightly different. Once you have the 2 measurments split the difference and that is the length from center hole to center hole. Also take into cosideration of the Heim-joints. This plays a big role in the length of the cross over BAR!!
