12-28-2009, 01:54 AM | #1 |
exhaust and bags
hey guys im putting my bags on my 68 and i think im going to have a problem in the rear, the over axle pipe for my exhaust will be hitting the axle when aired out. should i have the pipe re done to go higher and clear the c notch? what are you guys doing about this??
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308 2014 Chevy 2500hd duramax CCLB |
12-28-2009, 08:59 AM | #2 |
Redefining LowBudget
Re: exhaust and bags
if you can I would like to see a pick if you can get it over the axle and though the panard bar..t seems like most are dumping out either in front of the axle or out the side before the wheel
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. Mikes Sandwich Fair Run OCT 8th 2011
12-28-2009, 12:18 PM | #3 |
Mine dump before the axle.
'02 Harley Davidson XL1200C, Chrome everything '99 Tahoe, Removed trim/emblems/roofrack/runningboards, Custom grill, Smooth bumper, Lowered 2" on 20's '97 Jeep TJ, 2" lift, 32x11.50's '71 C10 Short Fleet, 454, TH400, Vintage Air, 4 Wheel discs, Posi, New bed sides/rockers/bumpers, Relocated tank, Bagged, Step notch, 20/22's http://www.myspace.com/ndweedz http://www.youtube.com/user/wdrthird "My lugnuts require more torque than your Honda makes" |
12-28-2009, 12:31 PM | #4 |
Farmtruck desciple
12-28-2009, 04:36 PM | #5 |
do you have any pics of your rear bag set up???
12-29-2009, 12:25 AM | #6 |
This link has some more info and a couple pictures of my setup. Hope this helps.
http://67-72chevytrucks.com/vboard/s...d.php?t=323736
12-28-2009, 01:11 PM | #7 |
someday it will be done!
I raised my bed floor so I didn't have to cut a hole in the bed and to make the extra room for exhaust.It was a lot of extra work,but I can run the pipes out the back without too much hassle.Another thing I've been considering is to get the pipes outside of the frame somewhere before the rear end.The truck is low enough that it wouldn't be too visible,and the panhard would be a non issue.
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore. '80 LWB 2wd beater '67 GMC long fleet (cab donor) '66 long step (parked till it's turn comes around) '65 short step (parts truck that will donate it's bed and possibly frame to the '66) '06 Grand Prix wife's car (she hardly lets me touch it) my pics |
12-28-2009, 03:33 PM | #8 |
hey rollie what happens when it gets to the wheels?? my tires fill ALL of it or are you thinking before the wheels....I have thought about roadster headers to get out side the frame from the get go so the pipes run behind the rockers...shhh I was alos thinking side pipes......I mean it is a 70...alittle shag on the dash and I'm in!!
12-31-2009, 02:01 AM | #9 | |
I'll probably be ducking my exhaust outside the rails right from the start as my air tanks are inside the rails under the cab. Lol what sidepipes aren't cool anymore?I was gonna do that to my 66 back in highschool but never got the cash together at the right time (maybe a good thing).
12-31-2009, 09:16 AM | #10 |
on a side note if you plan to tow out the back isn't a good idea ...trust me..behind the rear wheels would be ok though
12-28-2009, 07:58 PM | #11 |
Keep in mind any state safety requirements. Some states require them to exit frame rails others require only turndowns after the cab provided you don't have a camper installed. It would be a waste of coin to redo a system and have to change it again later.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
12-28-2009, 11:44 PM | #12 |
just my opinion (you asked) do what it takes to get it out the back. you'll be glad you did. "Exhaust should be heard, not seen"
The kid Build threads: 51 Jimmy http://67-72chevytrucks.com/vboard/s...d.php?t=154951 http://67-72chevytrucks.com/vboard/s...d.php?t=219902 http://www.classictrucks.com/feature...uck/index.html 68 C10 http://67-72chevytrucks.com/vboard/s...ad.php?t=50348 |
12-28-2009, 11:58 PM | #13 | |
im not going for horse power, just a clean custom cruizer!
