Old 12-28-2009, 12:57 PM   #1
damnyankee36
damnyankee36's Avatar
Trouble Finding Fittings
I never thought this would be a problem, but I can't find any tee fittings to run my pressure gauges!
I'm using 3/8" air line to the bags and planned on using 1/8" line for the gauges. The best I could find was at Suicide Doors. They have a 1/2" x 1/8" union tee.
My bags are all single port, so I can't use them to run the lines to.
What the hell am going to do!!!???
damnyankee36 is offline   Reply With Quote
Old 12-28-2009, 02:54 PM   #2
Shane
Shane's Avatar
Re: Trouble Finding Fittings
http://www.*****************/catalog/...-gauge-fitting
plug one port ... PTC 3/8" NPT to 3/8" tube on 2 ports ...
[img]http://www.*****************/files/imagecache/product_list/Brass_Tee_with_Straight_Fitting.jpg[/img]
Shane is offline   Reply With Quote
Old 12-28-2009, 04:07 PM   #3
damnyankee36
How'd I miss that? It looks like they are pipe threads, so I would also have to get NPT-compression fittings.
I found a way to do this. I picked up some 3/8" x 3/8" x 1/4" compression tees. The 1/4" port is just a hair larger than 1/8" pipe thread. I re-threaded the 1/4" port and used 1/4" NPT-1/8" compression fittings, the kind used for oil pressure gauges. The new threads are perfect.
I would still like to know how others connect their gauges to their systems.
Old 12-28-2009, 03:54 PM   #4
draggin86
draggin86's Avatar
you can use what is posted above or you can drill and tap your T fittings and put in a 1/8" line fitting into the T
draggin86 is offline   Reply With Quote
Old 12-28-2009, 04:11 PM   #5
71swb4x4
71swb4x4's Avatar
I have had great luck with www.hoseandfittings.com.
http://shop.hoseandfittings.com/catalog/Fitting.html
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 12-28-2009, 06:45 PM   #6
RunninLo
3DrDwn--the 'burb not the band
RunninLo's Avatar
I usually drill and tap but your local Parker Hanefin dealer as all kinds of stuff. Look for parker under hydraulic supplies in the yellow pages.
Josh
Slo and Lo that is the tempo.
'72 burb build page here:
http://67-72chevytrucks.com/vboard/s...d.php?t=259256
'89 GMC Dually crew build page coming soon.
88 4x4 crew DD
duallys past/present pics here:
http://67-72chevytrucks.com/vboard/s...46#post4001246
89 1 ton Dually rear flip kit install here:
http://67-72chevytrucks.com/vboard/s...d.php?t=354327
RunninLo is offline   Reply With Quote
Old 12-28-2009, 07:16 PM   #7
LMDGUY
LMDGUY's Avatar
Parker stores are life savers. The one in Phx are track sponsors and are very helpful any car questions
1973 C10 "Chain Reaction"
Street Trucks cover Feb 2012
2013 Silverado
1964 Cadillac
LMDGUY is offline   Reply With Quote
Old 12-28-2009, 08:14 PM   #8
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
As stated above, I just drill and tap where ever I need to.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 12-28-2009, 08:49 PM   #9
damnyankee36
I already have my tees installed, but I wonder if I could have drilled and tapped for the fittings into the valve body of my manifold? That would be slick and a lot more organized.
Old 12-29-2009, 01:42 AM   #10
ShowSS12
ShowSS12's Avatar
I carry these... Easy street Tee
The picture doesn't show it but they come tapped with 1/8 thread for the gauge fitting. They run $9.80 each and you will need some 1/8 PTC elbow or straights
Adam M
STX Designs
Motorcycles | Choppers | Hotrods
ShowSS12 is offline   Reply With Quote
