Watchin the rust grow
![]() Join Date: Oct 2008
Axle ID
I was looking at the frame of a pick up, 8 lugs, I didn't get a long enough chance to take any pictures or look at it very well (busy trying to get another one running) I know the frame was a 73-87.
The only number I got off of it was GM 82. Is that enough information to tell me what it is? D60 or Corp. 14 bolt I'm thinking.
1979 Chevy K10 (H/D Front end) - 350 w/ Holley Truck Avenger, Weinald Intake manifold, headers, bored .060 over, mild cam, Built up TH350 (TranStar Shift kit) with a part-timed NP203 t-case SOLD ($3,000) 1997 Chevy Silverado 1500 - 4.3 vortec, extended cab, 21 highway MPG, stock. "Red" SOLD ($3,000) 1987 Toyota 4wd Pick-up - work in progress, future DD SOLD ($1,850) 1998 Dodge Ram 2500 Cummins 5spd Quad cab - old 12 valve with some work done ![]() 2004 Chevy Silverado - Black, 4x4, 5.3L, stock for now Underneath that rust is a heart of gold
Re: Axle ID
front or rear axle?
srw drw? no d60 rear after 73+ drw can be a 14bff skinny or a d70 wide. srw can be a 14bff or 14bsf depnding on the year and gvrw. |
Re: Axle ID
I don`t know by the number.It wouldn`t be a Dana 60 from factory and most likely a 14-bolt.I it was an`80 or newer it could be a semi-floating 14-bolt,the 8-lug with no hub protruding.It looks like a 1/2t the way the drum goes on over the studs.
Re: Axle ID
A Dana 70 would be a dually, correct? I found out the pick up is a 81.
If I took the leafsprings off of it and put them on my halfton corp. 12 would they bolt up? I want a little more towing capability, I have the engine and transmission but the damn thing squats with anything more than 300 pounds.
Re: Axle ID
Yeah,on GMs the Dana70 would be on dual wheel pickups.The springs should bolt up.Measure from spring eye to spring eye,front to back.They should be 52"+/- on both trucks.The longer springs are 56".I doubt you`ll have that on either.Yo could disassemble the extra spring packs and add to your springs,also.Fine tune them.Most likely if you take the longest leaf (not main leaf w/eyes) an slip thae into your pack you`ll see a big difference.
#6 | |
Re: Axle ID
![]() I'm considering it, every weekend I have something heavy in my pick up truck and it squats, and to be honest it's a little embarrassing. (like an engine or a load of firewood or some scrap)
At the body shop.
Re: Axle ID
The short spring come in light duty 1/2 tons. The longer springs come in heavy duty 1/2 tons and bigger. If youve the short springs and the others are the long ones. Your frame already has the holes to relocate the spring hanger.
" That didnt make it any newer " " Dont antique the equipment " |
Re: Axle ID
At the body shop.
Re: Axle ID
Excuse me capt. leaf god The stuff ive been around had been that way
" That didnt make it any newer " " Dont antique the equipment " Last edited by KQQL IT; 01-01-2010 at 07:32 AM. |
Re: Axle ID
Hey 2ton,Im offering you some advise.You need to find some tact.Take the time to word things a bit better and you`ll be good.The way you worded that is downright inflammatory.We all offer our info based on our experiences.No one knows it all and we just try to help.No one knows everything.I`ve seen you post wrong info and I carefully corrected.I don`t know about you,but it matters to me and most other people "how" we are corrected.I`m open to being corrected.But,if someone goes about it wrong I ain`t listening and the critic is just a jerk.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 01-01-2010 at 10:04 AM. |
#11 | ||
Re: Axle ID
if you refuse to listen to good info or tech simply because you have thin skin or get your panties in a wad you are going to miss out on a lot, not just from me but in life. you are right, i dont know everything, i dont think i do, i do know a lot, the sad part is that alot of people dont seem to want to learn or are to busy wiping the tears away to learn. |
#12 | |
Re: Axle ID
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
#13 | |
Re: Axle ID
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 01-01-2010 at 09:13 PM. |
Re: Axle ID
What I meant with "fine tune".You could just take some leafs from the heavier pack and add them to yours,according to what works best.It depends on which length springs you add and where how it will change the ride/carrying ability.You wouldn`t have to remove your spring eye bolts.That`s usually a big pain to do.I`d try adding the longest leaf after the main.The first one w/o the spring eye (for bolt and bushing).The clamps from the heavier pack can be used,since they are larger.
#15 | |
Re: Axle ID
